Sponsored by: Kumho
Power Steering pressure
Old Aug 14, 2012 | 12:14 AM
Opossum's Avatar
Opossum
Anyone know what kinda pressure our/my power steering operates under?
Old Aug 15, 2012 | 10:12 AM
mark a.'s Avatar
mark a.
Depends on the pump. A good Chevy pump should put out around 1200 psi. The old big steel Ford pumps might get to 800 psi.
Old Aug 15, 2012 | 05:03 PM
Opossum's Avatar
Opossum
Good point, truck currently is a stock ford pump on a 87 F350 460, looking at swapping to saginaw pump and hydroboost.
Old Mar 14, 2014 | 11:09 PM
hillcogolfer's Avatar
hillcogolfer
Pw steering pump pressure
I'm driving an old rod build (by someone else)...a '50 Ford F1 with a 302 Ford in it. It's a cobbled up V-belt system and I would like to just find me a salvage yard-- complete Ford V-belt system and install that so that everything works together and most importantly...lines up.
The problem with that is, there's a GM Saginaw pump on there. BUT, it in fact makes the steering slightly "twitchy" and I am certain that it could actually make my steering have MORE feel and thus be more stable on the road if...it operated on LESS pressure.
So...since Ford pumps are known to have less pressure (from 1,200/GM to 800/Ford)....what would be wrong, in your opinion, with canning the GM pump and going with the Ford pump....and solve two problems at once?
Don Vito
Jul 9, 2018 05:10 PM
ike55
Aug 3, 2014 10:18 PM
Jeff and Nicolle
Jan 24, 2012 08:07 PM
kel1306
Feb 12, 2008 06:20 AM
gatorfan
Dec 22, 2005 10:09 AM
