Dim Inst. Lighying
Old Aug 13, 2012 | 01:03 PM
Dajudge51's Avatar
Dajudge51
Dim Inst. Lighying
I want to check and maybe replace inst. lightbulbs on my 69 Ranger. Do I need to remove the front of the panel for this job. If so are there any instructions that are written anywhere ? Also can brighter candle power bulbs be used and if so do u have the numbers ?
Thanks,
dajudge51
Old Aug 13, 2012 | 05:33 PM
jowilker's Avatar
jowilker
51 It has been a while, but I think you have to remove the face screws and lower the top front of the panel out on the steering column. New bulbs the same strength will increase the candle power greatly than the 40 year old ones.
John
Old Aug 13, 2012 | 07:00 PM
Dajudge51's Avatar
Dajudge51
Thx John !!
Old Aug 14, 2012 | 08:30 PM
jpcole9702's Avatar
jpcole9702
new bulbs
I took my cluster out, and cleaned everything, repainted the needles with some fluorescent model paint, and replaced the bulbs with some blue led bulbs.. everyone loves the look, looks amazing and much brighter... But you need to be careful of damaging the circuit board as being that old, they are pretty fragile! If you have any questions, please ask..
Old Aug 14, 2012 | 10:13 PM
Dajudge51's Avatar
Dajudge51
Guess I'm wondering how to remove the cluster. Any written instructions ?
Old Aug 15, 2012 | 03:33 AM
jowilker's Avatar
jowilker
Mines a 66, but the screws are all exposed, visible from the drivers seat. Remove them and pull the whole panel out. Be careful like JP sez, the wiring circuit is printed on the back and the bulbs are twist locked in, if I remember correctly.
John
Old Aug 15, 2012 | 06:26 AM
jpcole9702's Avatar
jpcole9702
no instructions needed...
This is a very simple task, there are three requirements to remove the cluster... They can be preformed in any order, remove front screws (approx. 8), disconnect the speedo cable from behind and under the dash, disconnect the rectangle connector from behind and under the dash (on my 70 it is on the right side of the cluster when you are sitting in the drivers seat). The connector has a tab on the top and bottom, so you must pinch those tabs and gently rock the connector to get it to come out. As I stated before, the printed circuit board is flimsy plastic and prone to being very brittle ($100 from LMC truck). Once you have those three things done, the cluster will just be loose and you can just pull it out and replace the 194 bulbs. I replaced mine with these bulbs:
Amazon.com: AGT Brand 4x 194 168 5-SMD Blue High Power LED Car Lights Bulb: Automotive
Not a perfect replacement, as the original 194's held in the little holders much better, but they look great and i haven't had any problems with them; or you can just buy the direct replacement which will also be much brighter.
Hope this helps, and again if you have any questions please feel free to ask.
kdwyer
1983 - 2012 Ranger & B-Series
13
Nov 20, 2021 04:18 PM
abe
Dec 30, 2015 09:26 PM
ukexplorer
Dec 4, 2014 02:21 PM
raldur
Feb 18, 2005 01:31 PM
Trampus
1978 - 1996 Big Bronco
Nov 15, 2003 11:04 PM
