Sponsored by: Real Truck
05 F-250 Issues
Old Aug 13, 2012 | 12:27 PM
Stormbringer's Avatar
Stormbringer
05 F-250 Issues
Problem.
I have an 05 F-250 SD 4X4 that threw these codes Saturday morning at 6:30 AM.
Current Fault Log
P2107: Throttle Actuator Control Module Processor
P2110: Throttle Actuator Control System - Forced Limited RPM
Pending Fault Log
P0446: Evaporative Emission Control System Vent Control Circuit
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
3 months ago I replaced the Throttle Control Motor on the Throttle Body.
I get the LIMP mode Icon on the dash. Took several tries to clear the code. Truck runs fine until the temp of outside are starts to drop below 80 F and then its back in LIMP Mode until air temp rises... Really??
I mean Really?
Ford says it the PCM.. Had it replaced 2 years ago no warrenty... go figure.. Thanks FORD..
Any suggestions?
MikeDVB
2015 - 2020 F150
13
Dec 18, 2021 11:35 PM
bwitty
Jun 18, 2010 10:57 AM
mlytc
Feb 28, 2010 01:29 PM
wsconner
Sep 10, 2009 07:53 PM
44dwarf
2004 - 2008 F150
Mar 11, 2008 04:44 PM
