where do I get bolts
Old Aug 12, 2012 | 05:48 PM
85grey's Avatar
85grey
I was adding oil to the 85 and it started running out of the bottom of the fill tube. I could see a hole in it so i removed it and found that all three of the 5/16 12 point bolts had vibrated out and been rotating around in that fill tube. Obviously the threads and the heads of the bolts are all screwed up. Where do I get others?
Old Aug 12, 2012 | 05:59 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Any hardware store will have them. You dont need grade 8, but if its worth doing its worth over doing lol. Grade 5 would be just fine.
Old Aug 12, 2012 | 08:44 PM
84-6.9L's Avatar
84-6.9L
I'm not surebutyou may have issues getting the heads of regular bolts to fit in the hole. Try going with alloy "socket head cap screws" from the hardware store, they are strong and with the smaller allen head they should fit with no issues.
Kyle Wood
Nov 7, 2016 09:10 PM
fabieber
Nov 14, 2015 10:18 PM
Redtoga
Nov 15, 2013 10:14 AM
spidermonkey
Apr 24, 2008 12:16 PM
Terran
Jul 28, 2006 06:52 PM
