Low compression
Old May 12, 2003 | 09:12 PM
aj3816's Avatar
aj3816
Unhappy Low compression
Long story here, but now that the machine shop has finally got my 390 heads done correctly now after the 3rd time . I have found I have one cylinder that is only pumping up to 55psi, wet or dry, all the others are between 128-140psi. The cylinder walls are all nice with no gouges and no big lip at the top. I am on really tight budget and need to get this thing running again. So is it possible to change just one set of pistons ring. Yes I know that this should not really be done, but I am in a big pinch.
Old May 13, 2003 | 04:39 AM
Ratsmoker's Avatar
Ratsmoker
Low compression
If your compression doesn't come up when you add oil to the cylinder, you have a valve that isn't seating right. Who is doing the heads? Have them pressure checked before you install them. It only costs about 15 bucks and should be done anyway by the guy performing the headwork.
Old May 13, 2003 | 06:30 AM
macguyver's Avatar
macguyver
Low compression
I agree with ratsmoker. It's probably a valve. If you do a leakdown test before you pull the head(s) back off you should be able to tell where the compression is going.
Just a thought... If the pushrod or the valve stem is too long the valve won't seal and the compression will be low. If you do a leakdown with the rockers in place (make sure you're on compression) and it shows leakage but with the rockers removed the leakdown doesn't show leakage, the valve train is holding the valve open.
Quick and dirty test for valve sealing... With the head off and the combustion area dry, spray enough penetrating oil through the port to cover the valve sealing surface. If there's any leakage into the combustion area, the valve isn't sealed.
Old May 13, 2003 | 08:52 AM
aj3816's Avatar
aj3816
Low compression
Well I tried a leak down test without the vavle train on and I couldn't even build up enough pressure to check it. Sound like it was going right through the exhaust valve. All other will air up and hold pressure. So I just took the head off again and will be dropping it off to the shop. This will be the last time I do any business with this shop. And if it is the valves, the nice people at the shop said they would actually cover my labor for this deal.
Old May 13, 2003 | 01:56 PM
macguyver's Avatar
macguyver
Low compression
It would be nice if they covered the gaskets too.
jbarendrecht85
Aug 11, 2016 01:45 PM
c2z4s9
73
Feb 29, 2016 07:14 AM
Christopher Layton
Feb 26, 2016 11:45 AM
jjfletcher79
Jun 1, 2015 09:59 PM
toolboxjunky
Apr 9, 2009 05:01 AM
