...strange problem.
Old Aug 9, 2012 | 11:20 PM
PatientZero's Avatar
PatientZero
...strange problem.
Okay. I'm working on my 1978 f100 with a 300. Auto transmission and original Carter yf. Carb. Truck runs like a dream in park or neutral, but as soon as put into gear, it idles way too low and backfires through the Carb when given gas. I've replaced plugs, wires, coil. Rebuilt carb and changed manifold gaskets. Adjusting timing doesn't seem to be helping any. Does anybody have any ideas about what i may be missing?
-patientzero
Old Aug 9, 2012 | 11:24 PM
devino246's Avatar
devino246
Start checking all your vacuum lines. Sounds like a vacuum leak.
Old Aug 10, 2012 | 07:13 AM
fmc400's Avatar
fmc400
MSEE
Agreed, sounds like a vacuum leak. I'm also going to assume that when you adusted the timing, you used a light and NOT by ear.
Old Aug 10, 2012 | 10:46 AM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Check your booster, get a pair of vice grips and use them to clamp them onto the vacuum line for the booster then test drive it.
Sam
cosmaar1
18
Sep 11, 2016 08:39 AM
RShaips
16
Dec 15, 2014 03:40 PM
VocaTexas
Jan 26, 2014 12:55 PM
OzFTrucker
17
Sep 27, 2013 10:09 PM
fordtime
Mar 16, 2004 11:34 AM
