Hey guys I am thinking about upgrading to a 3g alternator on my 70 f250 ranger.it has bean in the 100 out here and my truck is overheating a little In traffic. I have a mark vlll electric fan that I want to install, but a friend told me I need to up grade my alternator.what is involved in this project where do I get the alternator, dose anybody have any pictures or advice on how to tackle this, any help will be appreciated thanks.
There are literally dozens of donor cars. Look for a Taurus from the 90s with a V6, most will have a 3G configured right. There are lots of others but I can't find the list right now. If you just google 3G conversion, you will find links to other Ford sites where it is detailed. Personally, I just forget the stock amp gauge since it;s junk anyway and install a volt meter. Then you can one wire the 3g. Make sure you get the plug with it and the center wire is a small plug that stays where youi found it. Then loop the yellow and white "A" wire to the hot lead and the hot lead can go with to Batt + (better to go to the solenoid though. They also recommend using the 175 amp mega fuse and 4 gauge wire for the +. I am running an 80 amp circuit breaker because I don't ask much of my 3G. Just what it takes to fire the points. run the lights and fan.
3G 130amp Donor Vehicles:
(1994-95) Ford Mustang 5.0L
(1994-00) Ford Mustang 3.8L
(1994-97) Ford Thunderbird, Mercury Cougar 3.8L
(1990-95) Ford Taurus, Mercury Sable 3.8L
(1993-99) Ford Taurus, Mercury Sable 3.0L
(1995-9 Ford Windstar 3.8L & 3.0L
(1991-94) Lincoln Continental 3.8L
(1992-97) Ford F Series Pickup
(1992-96) Ford E Series Van
hey guys i have a problem i just installed a 3g alternator and now my truck wont start when i turn the key nothing, but if i jump a wire from the battery pos to the three wire harnes left from the old wire i took out it starts right up what did i do wrong please help need my truck for work thanks
Hio thank for the quick response, now by the picture you posted I understand that you retrofitted the old wire harness to work with the 3g hardness, what about the cable for the battery, did you run the cable from alternator to mega fuse to starter solenoid on battery side.
Hio thank for the quick response, now by the picture you posted I understand that you retrofitted the old wire harness to work with the 3g harness, what about the cable for the battery, did you run the cable from alternator to mega fuse to starter solenoid on battery side.
Thank you Hio, you posted a link about this 3g upgrade wen I first asked, sorry but I am not to good at understanding wiring diagrams thanks again,I know I can depend on you guys.Now I am ready for the mark Vlll electric fan,I will be asking questions again, you guys rock.
