new AC compressor problem, clutch slip
Old May 12, 2003 | 05:36 PM
BroncoScott's Avatar
BroncoScott
I just got an Airco compressor, dryer, orfice for my '89. Flush, replace seals, and evacuate. Runs nice and cold. Problem is clutch sometimes slips a little or even real bad. Pressures are reasonable. Other thing I am not happy about was while pulling a vacuum I had to find a sweet spot by rotating the shaft or I couldn't get good vacuum, 28.5. Airco may not have anybody technical. One year warranty though. Help
Old May 12, 2003 | 06:04 PM
mantta's Avatar
mantta
If your clutch is slipping I would suspect that you are running a super high discharge pressure. This could be caused by an overcharge, air in the system or a blocked condenser (air or refrigerant side). It could also be caused by low voltage to the clutch.
Old May 12, 2003 | 06:12 PM
BroncoScott
high side at idle never got above 165 LBS. Voltage to the conpressor is 12.4V. Condenser and Evap. flushed with little resistance on the condenser and none on the Evap.
Old May 12, 2003 | 06:15 PM
mantta's Avatar
mantta
I guess it is time to see if that warranty is any good!
Old May 12, 2003 | 06:17 PM
BroncoScott
What about clutch shims, add or remove? I really hate to evac the system and not have AC for 2-3 weeks. Haven't had it since last August so I got spoiled in 2 days.
Old May 12, 2003 | 06:39 PM
mantta's Avatar
mantta
There are shims behind the hub on both the FS-6 and the 6E171. I don't know witch one you have. The clearance between the hub and the pulley should be .021" to .036". If yours exceeds that I would remove a shim.
Old May 12, 2003 | 07:05 PM
BroncoScott
FX/15
Old May 13, 2003 | 06:17 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I'd explore the possibility of a weak clutch before I pulled it and had to deal with another recharge.
Old May 13, 2003 | 07:48 AM
steve83's Avatar
steve83
Are there shims on that compressor? There should be SOME way to adjust the gap. It should be JUST wide enough that it doesn't drag when it's off.
bigred177
40
Sep 22, 2014 08:39 PM
Bruker
Garage & Workshop
15
Jul 9, 2007 07:19 PM
BEL-150
1997 - 2003 F150
Aug 23, 2005 04:10 PM
nb1997
May 30, 2005 11:50 PM
ivanribic
Garage & Workshop
17
Jan 28, 2005 12:30 AM
