1978 - 1996 Big Bronco
Starter problem?
Old Aug 16, 2012 | 01:50 PM
udsuth78's Avatar
udsuth78
definitely check that all cables are clean and tight, also if they are very old just replace them. its crazy how many times starting issues trace back to a bad or loose cable especially when its an intermittent problem
Old Aug 17, 2012 | 02:34 AM
Bubba Jones's Avatar
Bubba Jones
Originally Posted by Edgethis
...the stock cables are known to corrode internally on these trucks.
+1. I know my cables are starting to corrode internally so I should have them replaced soon. I already replaced the connector ends but I have shortened them somewhat and they are starting to get a little too short. Bad connections/cables cause starting issues pretty frequently, even if the connection doesn't seem too dirty or bad, a little bit of hidden corrosion can make a big difference so cleaning all connections surely won't hurt. If that doesn't work then like others said, it's probably the solenoid (and it sounds kinda more like the a bad solenoid then bad connections, but cleaning connections is free!).
Old Aug 17, 2012 | 07:09 AM
udsuth78's Avatar
udsuth78
if the cables are corroding internally then there is your problem. i was having the same problem on a 92 chevy i had and a new set of cables solved it
Old Aug 17, 2012 | 10:58 AM
Kemicalburns's Avatar
Kemicalburns
start with the inexpensive stuff first and the obvious (cables)
Old Aug 17, 2012 | 11:31 AM
Encho's Avatar
Encho
The Southernmost Mod
Check the small wire that connects at the starter. Clean and protect from the elements its terminal at the starter (heat shrink should come handy here).
86waterpumper
Apr 7, 2019 06:53 PM
neaners
Apr 15, 2015 10:01 AM
abranz
Nov 16, 2014 01:07 AM
DTX88
2004 - 2008 F150
Mar 2, 2014 09:15 PM
1990xlt
1983 - 2012 Ranger & B-Series
Mar 26, 2001 07:52 PM
