1978 - 1996 Big Bronco
Starter problem?
Old Aug 8, 2012 | 04:40 PM
Broncobudy's Avatar
Broncobudy
Starter problem?
My 96 5.8L auto Bronco won't start. Battery fully charged, dash lights come on, dome light comes on, radio works, but nothing happens when I turn the key. What a few things I can do either narrow down cause or rule what isn't the problem? Thanks.
Old Aug 8, 2012 | 04:44 PM
ford1977owner's Avatar
ford1977owner
is it just clicking? or is it turning over?
Old Aug 8, 2012 | 04:45 PM
ford1977owner
my dads 92 5.8l was doing the same thing but when u would turn the key it would only click, ended up being the starter
Old Aug 8, 2012 | 04:51 PM
Broncobudy's Avatar
Broncobudy
It will click. Does not turn over.
Old Aug 8, 2012 | 05:10 PM
ford1977owner
could be a starter issue, as i said my dad had the same problem with his 92 and it was the starter
Old Aug 8, 2012 | 05:33 PM
Kemicalburns's Avatar
Kemicalburns
first make sure your cables are all clean and snug. smack your starter with a hammer a few times then try again. if it still clicks pull the starter and have it tested. if it clears than the solenoid on the fender is the culprit
Old Aug 9, 2012 | 02:38 AM
Bubba Jones's Avatar
Bubba Jones
Well a potentially dangerous thing to do is bypass the starter solenoid or starter itself with a screwdriver or other metal object with a non metal handle. Just connect the two ends of the starter solenoid with the screwdriver with the ignition on to see if that works, then you'll know if you have a bad solenoid or connections there. You can do the same thing with your starter, and if your starter turns over then you know that's good and you probably have a bad connection.
Make sure you're in neutral if you decide to do this and be prepared for sparks!!!
Old Aug 9, 2012 | 07:54 AM
harold1814's Avatar
harold1814
I was having the same problem with my 1989 Bronco. The first thing you need to do is narrow things down as you already have by saying it clicks. There's only a few things it could be now since your battery is fully charged. Check the fuel pump and if you hear it clicking then go on to the starter.
Old Aug 9, 2012 | 10:23 AM
Kemicalburns
what the hell does the fuel pump have to do with this perticular situation??
Old Aug 9, 2012 | 12:52 PM
harold1814's Avatar
harold1814
hey now sparky watch the language
Old Aug 9, 2012 | 01:16 PM
harold1814's Avatar
harold1814
and i wasn't saying it was the fuel pump. If the fuel pump is clicking and on it means it has plenty of juice to turn over the starter. Ford starters are about as tough as there trucks so your best option would be just to replace it or buy your self some time and get one from a scrap yard. Starters on ford's can just be bolted in and ready to go.
Old Aug 9, 2012 | 02:47 PM
Encho's Avatar
Encho
The Southernmost Mod
My bet is on the starter solenoid, it's the cheaper part and the easiest one to test, with the key on the ON position, use a screwdriver to create a bridge between the threaded poles of the solenoid (The black cylindrical part on the fender, next to the battery and with a bunch of wires atteched). Of course, if it's an auto do this while in Park, if it's a manual, do this while in Neutral (by the lack of mentions of attemps to do a rolling start, I'm guessing it's an auto). If the engine turns, then the cause is the solenoid, just replace it.
If the engine doesn't turn after you try the screwdriver, then there is another cause.
Old Aug 16, 2012 | 10:59 AM
Broncobudy's Avatar
Broncobudy
Starter problem?
Thanks everyone. I wanted to let you know I was out of town when I posted this thread and when I came home I tried starting again and it started right up without changing a thing. Any ideas on this? I bought a new started and plan to hang on to it for a little while to see what happens, but so far it runs smoothly.
Old Aug 16, 2012 | 11:58 AM
Encho's Avatar
Encho
You have a starter solenoid that's starting to get stuck, it will do it this every now and then, until it gives out completely.
Old Aug 16, 2012 | 01:03 PM
Edgethis's Avatar
Edgethis
I agree, I've repalced many a starter solenoid on my Bronco. I'd prolly repalce it next time you ahve a chance, its cheap and easy to swap out. Also might look at getting new cables, the stock cables are known to corrode internally on these trucks.
Good to hear you have it back on the road tho.
