Injectors
Old Sep 17, 2008 | 11:13 AM
alteredspeed's Avatar
alteredspeed
Injectors
Ok I have a 1993 7.3 IDI non turbo. Im going to replace the ijsectors, but will be adding a turbo down the road.Due I get the injectors for the turbo or not?
Old Sep 17, 2008 | 06:05 PM
KJLYPW's Avatar
KJLYPW
Unless you are planning to change the IP as well, I would stick with the E code for now, turn up you IP when you do get a turbo, the E codes will flow plenty of fuel.
Old Sep 18, 2008 | 07:08 PM
Ironman03R's Avatar
Ironman03R
I'd stay away form the G's unless your trying to keep the smoke down. The G has the biggest hole out of the injectors I've measured but the pintle is more restrictive they also have a higher pop off.
Old Sep 18, 2008 | 10:50 PM
basfire's Avatar
basfire
Ironman,
What is a pintle and what does it do? What's a pop off?
Old Sep 18, 2008 | 11:22 PM
Blueovals&Blacksmoke's Avatar
idk what pintle is but pop off is when the injector cracks open and sprays fuel into the cylinder
Old Sep 19, 2008 | 08:06 AM
Ironman03R's Avatar
Ironman03R
That would be the part in the injector that opens to allow fuel to flow through. It moves up to allow flow when the IP pressure has reached the set "pop" pressure, when the pressure drops, the pintle moves back down to its seat and extra fuel is returned to the tank through the return port in the injector body.
Old Sep 19, 2008 | 11:12 PM
S.P.'s Avatar
S.P.
Run your finger tip over the end of the injector,that little pin sticking out is the pintle...
on the otherhand...a pinto was a moltov cocktail that was made by ford .. donot confuse the two...
