EGR Delete Tune
Old Aug 8, 2012 | 05:05 PM
Fulthrotl's Avatar
Fulthrotl
Originally Posted by MC5C
How about leaving the EGR valve in, disconnecting the cable and plugging it into another EGR valve that you sit on top of the engine in a plastic bag. Would that leave the EGR valve in the actual engine closed and prevent exhaust gas from flowing, and not get codes or fan issues?
Brian
it'll throw a low flow code eventually, i believe.
i was going to do that, but in a van, there is no room for an
extra one under the doghouse, so that didn't happen.
Old Aug 8, 2012 | 06:03 PM
Chrisdrm10's Avatar
Chrisdrm10
Originally Posted by bpounds
Carburator cleaner, and a toothbrush. Be careful to keep it out of the upper part, especially the weep holes.
Just concentrate on where it opens at the very bottom with the carb cleaner?
Old Aug 8, 2012 | 06:21 PM
bpounds's Avatar
bpounds
I think you'll know, once you've got it out. If you've never had it out, I would run to the dealer and pickup a new seal kit. Otherwise you might be down for a while if you cut or tear one.
This is a pic of mine, coupla years ago.
Old Aug 8, 2012 | 06:50 PM
Chrisdrm10's Avatar
Chrisdrm10
What do they run? Is it okay to take a damp toothbrush to the upper opening? Or. An I spray it all and let it dry completely before re-installing?
Old Aug 8, 2012 | 06:51 PM
Chrisdrm10's Avatar
Chrisdrm10
* or can I...
Thx for all the help BTW
Old Aug 8, 2012 | 08:22 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
the pcm will throw a code for lack of egr flow. A tune/tuner would work best, but is the most expensive option. But then you could begin modding madness!
Old Aug 8, 2012 | 09:01 PM
Chrisdrm10's Avatar
Chrisdrm10
Bpounds, I'm assuming you do not have a delete then? Dontou just clean your EGR at regular intervals? If so, how often?
Old Aug 8, 2012 | 09:15 PM
bpounds's Avatar
bpounds
Correct. I am not deleted, and I don't believe a delete is necessary for a reliable 6.0. I do pull the EGR valve once a year or so, not really on a schedule. Just whenever I feel the spirit move me.
Old Aug 8, 2012 | 09:29 PM
Chrisdrm10's Avatar
Chrisdrm10
My concern with a delete is the potential TX emissions inspections if the USAF moves me back there. By my reading it seems the EGR is the stem of a lot of 6.0 problems. If I keep mine clean and get a SG II to detect codes I think I should be on the right track for a good running truck.
Old Aug 9, 2012 | 05:42 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Thats part of the solution, being pro active about know issues with our engine!
Old Aug 9, 2012 | 06:25 AM
bismic's Avatar
bismic
If the EGR system begins causing problems, it is usually only a symptom of something else (poor combustion, plugging oil cooler, bad software, bad sensor, etc)
Old Aug 9, 2012 | 07:36 AM
Chrisdrm10's Avatar
Chrisdrm10
With those four codes, would it be just the EGR system? I would think I would get a code if I had bad combustion, maybe not one for the oil cooler, correct?
Old Aug 9, 2012 | 10:52 AM
  #28
bismic's Avatar
bismic
Often times you will have no codes when injectors cause problems or sensors are biased, but yes, a bad EGR valve can cause issues by itself.
Old Aug 9, 2012 | 10:59 AM
  #29
Chrisdrm10's Avatar
Chrisdrm10
Okay, noted. I appreciate the help.
Old Aug 12, 2012 | 09:18 PM
  #30
Chrisdrm10's Avatar
Chrisdrm10
Mine was about double the dirtiness of yours. Had to pick out soot from the weep holes. Didn't spray cleanner up there though. We'll see how she runs tomorrow. Just put it back in with a new seal kit. I'll be cleaning that dude yearly for sure.
