Engine hesitation question
Old Aug 8, 2012 | 10:32 AM
AkF250HD's Avatar
AkF250HD
It's done this since I've owned it and I never thought much about it but i'd like to know if this might be a common thing or if there is something I can do to fix it. I do know that the previous owner put new points, rotor, and a distributor cap in it.
When I put my truck in gear and push on the throttle, there is a very slight hesitation that lasts only a second or so. When I sit at idle after startup it seems to be fine, I can rev it all day long with no hesitation. I ran a can of Seafoam through the front tank and it didn't fix it. Any ideas of what it might be? 97 F250HD with the 460.
Old Aug 9, 2012 | 09:50 AM
AkF250HD's Avatar
AkF250HD
Anyone have any idea of what to look at first? It doesn't appear to be anything serious but i'd like to get it fixed if I can.
Old Aug 9, 2012 | 10:17 AM
rla2005's Avatar
rla2005
There are no points in a 1997 Ford anything including your F250. I see no mention of replacing spark plugs, wires or fuel/air filters. Start with the basics then work your way out from there.
You should also check for codes. Many times there can be a problem or code stored in Continuous Memory (CM) without turning on the MIL light.
Old Aug 9, 2012 | 10:20 AM
mr.fordneck's Avatar
mr.fordneck
Plugs
Wires
Clean the throttle body
EGR
Fuel Filters
Fuel Pump
Could be many things
Check fuel pressure
Old Aug 9, 2012 | 11:29 AM
Lead Head's Avatar
Lead Head
If it has good power while driving besides the hesitation, I would suspect a faulty TPS or MAP sensor causing the hesitation.
First pull the codes, then I'd grab a multimeter and check the TPS voltage with the key on, engine off. The voltage should rise smoothly and steadily as you open the throttle, and be between 0.5 and 1.1 volts at the idle position.
Does it hesitate with the engine hot, cold, or both?
Old Aug 9, 2012 | 11:35 AM
AkF250HD's Avatar
AkF250HD
It does it when it's hot or cold and only when I initially hit the throttle. The throttle is a bit stiff when I push it down too, don't know if that has anything to do with it but I thought i'd mention it.
As far as the dist cap and such, I didn't know it didn't have points but I do know the previous owner changed the cap and the plug wires look new also. I'll check the plugs while i'm at it.
How do I check codes, this truck does not have OBD II on it but I do know that it has a connector under the hood, can't remember what it is called though.
Old Aug 9, 2012 | 12:54 PM
rla2005's Avatar
rla2005
Some refer to it as the Test connector, Data Link, etc. Follow this: Fuel Injection Technical Library » How To Run a Self-Test
Or purchase one of these: Equus 3145 Code Reader
Old Aug 9, 2012 | 01:47 PM
AkF250HD's Avatar
AkF250HD
OK, I did the self test and it came back with a system pass code of 1 1 1. I Guess i'll start checking the simple stuff first and see what I can dig up.
Thanks for the link rla2005.
Old Aug 9, 2012 | 03:07 PM
rla2005's Avatar
rla2005
That is a good start. I assume those codes were from the Key On Engine Off (KOEO) tests and Continuous Memory (CM)?
Old Aug 9, 2012 | 03:21 PM
AkF250HD's Avatar
AkF250HD
Yes sir, you are correct.
Old Aug 9, 2012 | 03:39 PM
rla2005's Avatar
rla2005
Reply in wrong thread......
Old Aug 9, 2012 | 03:42 PM
AkF250HD's Avatar
AkF250HD
That's not my thread rla2005. My idle is right around 600 rpms.
Old Aug 9, 2012 | 04:15 PM
rla2005's Avatar
rla2005
My mistake.....too many open windows. I apologize.
Old Aug 9, 2012 | 04:23 PM
AkF250HD's Avatar
AkF250HD
No problem.
Old Oct 1, 2012 | 12:38 PM
AkF250HD's Avatar
AkF250HD
I thought I would post up what I found on this hesitation problem. I finally got around to getting a timing light so I disconnected the SPOUT connector and checked the timing, it was down near 7* so I adjusted it to about 11* and the hesitation disappeared and it seems to get up and go a bit better. Hoping it might help just a tad with mpg but if it doesn't that's ok.
