Sponsored by: Auxito
possible trans issue?
Old Aug 8, 2012 | 08:38 AM
Tex1986's Avatar
Tex1986
Greeting Gentlemen,
98 F150, 2wd, 4R70W, 4.6, 250,000 miles, maintenance is up to date. Here's the deal, lately when I go to accelerate, there is no power whatsoever. When downshifting, from OD-3, 3-2, 2-1, the RPM's go up, but there is no acceleration as there should be. It gradually picks up speed, but nowhere near like it did a week ago. I guess the best way to describe it is it feels like there's a heavy trailer attached to the truck. Last trans flush was at 200k. And yes, I do realize this is a tiny, high mileage motor pushing a 3k lb vehicle. I can't even safely accelerate to merge with highway traffic its that slow. Trans slip? worn out trans? idk... help me... please :P
Old Aug 8, 2012 | 09:43 AM
dbreckman's Avatar
dbreckman
I'm sure you thought of it but double check your trans. fluid. My 01 does the same thing when it gets low. Also have you thought about having the exhaust flow checked, catalytic converter may be getting clogged.
Old Aug 8, 2012 | 09:50 AM
Tex1986's Avatar
Tex1986
Thank you and yes, I did think of that. I can't believe I forgot to mention fluid. I checked it last night and it's bright red, smells like it came right out of the bottle. If anything, fluid might be a lil high. It just started in the last 2 days, all of a sudden, nothing changed except I rotated the tires.
Old Aug 8, 2012 | 03:56 PM
Tex1986's Avatar
Tex1986
Is it possible solonoid? Im electrically ignorant but it has been raining HEAVILY the past two days. Converter lockup, sensor issues?? Im just stabbing in the dark here.
Old Aug 8, 2012 | 05:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's really a stab in the dark.
Has the OD OFF light flashed? Does the light work?
With the truck stopped, in drive, press the brake as hard as you can and floor the go pedal. Hold it for NO MORE THAN 5 SECONDS. That part is important, so I'll repeat it. DO NOT HOLD THE GO PEDAL DOWN FOR MORE THAN 5 SECONDS!!!!!!!!!!!
What RPM did the engine get to?
Old Aug 8, 2012 | 10:12 PM
Tex1986's Avatar
Tex1986
Thank you for stopping in sir! The OD light works, has not flashed. I did as you said and the tires broke loose about 22/2400 RPM. Had the same issue today when I first started driving it, but it got better as the day continued. IT's still not where it feels like it should be. Now that is perception, not actual fact. Doing a manual downshift into 2nd, there was no noticeable increase of torque or power anywhere in the powerband. That's all I can remember off the top of my head right now.
BiggDogg77
Jan 30, 2013 07:01 AM
robjs111
1997 - 2003 F150
Nov 16, 2009 04:53 PM
WorkVan58
Aug 4, 2008 07:28 AM
superduty4x4
Mar 29, 2008 03:06 PM
ford390gashog
Apr 10, 2004 09:00 PM
