Sorting out a one wire 3G
Old Aug 7, 2012 | 06:11 PM
willowbilly3's Avatar
willowbilly3
I have a one wire large frame 3G (yellow/white "A" wire to hot and center wire in it's original plug) on my hotrod. No charge so I took it out, had it bench tested and it charged with the fields grounded. I had another small frame that I knew worked when I removed it a couple years ago, or I thought it did. So I used that regulator. Still no charge but will still charge when full fielded. Did I get a second bad regulator or did I miss something? Case ground is good.
Old Aug 8, 2012 | 11:41 AM
Franklin2's Avatar
Franklin2
I am not sure what type of regulator you are using, if you are grounding the field to make it charge. It would have to be a special aftermarket regulator if it's only one wire. I believe I would get a standard 3g and use the stock regulator, then you will have two wires instead of one, and a much more common setup.
Old Aug 17, 2012 | 11:20 AM
willowbilly3
Thanks, I had to dig through 6 pages on the search to find the right wiring diagram. Oddly enough it came from the same site as the incorrect diagram I had (unsuccessfully) tried.
Here is the correct one for anyone interested.
http://www.bcbroncos.com/3ginstall.pdf
Here is the incorrect one I was trying to use, and thought I had an bad regulator because it would charge when I full fielded it.
http://www.bcbroncos.com/3g1wire%20w...ter%20mark.pdf
Not a one wire hook up but still plenty simple. One wire 3G alternators can be found on ebay and other sites, not sure how they do it, maybe a different regulator.
If you don't run the LG/Red wire through the switch, it will drain the battery.
Old Aug 17, 2012 | 11:31 AM
Franklin2's Avatar
Franklin2
Sounds like you are well educated now on 3g's. They do use a special regulator for the one-wire alternators, and the trick is like you said, getting the regulator to bring the alternator "online" and "offline" so it will not drain the battery. Of course the one wire regulators do not have the green/red, I have heard some of them monitor the dip in voltage when the starter is turning the engine, and use that as a sign to bring the alternator online.
I am not a fan of them, I like to be able to go to the store and get one off the shelf if I am down, and bolt it on and go. I don't want to have to wait for a special mail order alternator to come in before I am up and running again.
Old Aug 18, 2012 | 04:18 AM
willowbilly3
I agree, that's why I have the $10 junkyard version I wired myself. But that's pretty much this whole car, built in the spirit of the 40s-50s when you found parts and made them work instead of flopping down the plastic for kits.
cheddar89
Jan 25, 2012 04:43 PM
4drf350
1966 - 1977 Early Broncos
Jan 21, 2012 06:47 PM
gusso
Electrical Systems/Wiring
Jul 10, 2010 12:02 PM
tom1979
Oct 14, 2007 11:06 PM
pootscratch89
Feb 23, 2006 09:35 AM
