1966 - 1977 Early Broncos
what STA stand for
Old Jan 20, 2012 | 10:53 AM
4drf350's Avatar
4drf350
Post what STA stand for
HI Everyone : I am trying to get my bronco to charge, I have 3 wire I think that go to the alternator there are 4 post on the back all the wire drawing I have don't tell you what goes where , there is a STA, FLD ( field ) I know what BAt is I have that hooked up . There is a white wire an a green-red stripe an ground I have the hooked up also. Or should I up grade to a newer alt. Thank your for your help . Rick
Old Jan 20, 2012 | 01:57 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
STA is stator. Your choice on decision to upgrade. 3G upgrade will do away with the external regulator.
Old Jan 21, 2012 | 06:44 PM
Boba Fett's Avatar
Boba Fett
Two things.... One a wiring diagram for that year will give you where those wires go by color....and get that alt charging....
If you look at the plug for the voltage regulator if will also tell you where the wires go.... The lugs on the regulator for sta and fld correspond to the lugs on the alt...
Old Jan 21, 2012 | 06:47 PM
Boba Fett's Avatar
Boba Fett
http://www.junkyardgenius.com/charging/ford02.html
This link will help.... Upgrading to a one wire is another option.... You can either use a gm alt from the 70s to 80s or a ford 3g or an aftermarket bolt on from mean green or powermaster...
willowbilly3
Electrical Systems/Wiring
Aug 18, 2012 04:18 AM
robs01f250
Dec 15, 2010 12:47 PM
gusso
Jul 10, 2010 12:02 PM
rockdawg84
Oct 22, 2007 12:05 PM
pootscratch89
Feb 23, 2006 09:35 AM
