Sponsored by: Real Truck
Front End Problems on a 7.3
Old Aug 7, 2012 | 06:09 PM
planofootball19's Avatar
planofootball19
Hey guys i have a 2001 f250 4x4 with the 7.3. we bought it and it had some pretty bad front end problems, replaced upper and lower ball joints on both sides and while in replacing ball joints noticed bad hubs so we replaced those too. Its a little better but the truck still wonders really badly, it was never in an accident that reports show. What should be the next thing i should check, possibly the steering stablizer? any help is greatly appreciated as im not too farmiliar with front ends.
Old Aug 7, 2012 | 08:05 PM
mikeismadness's Avatar
mikeismadness
How do the tie rods look?
IMO your gearbox is worn and probably needs replaced. Big problem on these SuperDuty trucks it seems. Redhead makes a nice steering box
Old Aug 7, 2012 | 08:12 PM
sand_fiend's Avatar
sand_fiend
Did you get the front end re-aligned. bad camber "I be-leave it is" will make your truck wonder. Tires are the next thing if everything has been changed.. A twisted cord in a tire will make it wonder ..
Old Aug 7, 2012 | 08:14 PM
timf150's Avatar
timf150
I replaced upper and lower ball joints and all tie rod ends. I also replaced the sway bar bushings on the front sway bar, new shocks, and new steering dampener.
As mentioned a worn out steering box can cause issues and many have good things to say about the RedHead box.
Tim M
Old Aug 8, 2012 | 04:10 AM
JMM-MD's Avatar
JMM-MD
I did almost the same as TIMF150 "upper and lower ball joints and all tie rod ends. I also replaced the sway bar bushings on the front sway bar, new shocks" I then had it aligned, I did not replace the sterring stabilizer (did not have one, looks like the mounting bracket for it is all mangled) but I also put a 2.5" leveling kit and new Panhard rod, and the sway bar link bushings, would guess that TIMF150 did them as well just did not mention them - and the truck handles great.
Old Aug 8, 2012 | 06:25 AM
redford's Avatar
redford
FTE Leadership Emeritus
First, inspect or have the front end inspected by a good shop. Mke sure everything is tight.
Make sure your steering gear box is OK.
Have the truck aligned. Ask them to dial in as much positive caster as they can (within specs). Too much negative caster will cause the truck to wander.
Old Aug 8, 2012 | 06:33 AM
Texas Chain Ring's Avatar
Texas Chain Ring
I had brand new tires put on, had brand new outter tie rod ends and new shocks and an alignment done and then found out the play in the steering wheel, the truck wondering around on its own, is due to the steering gear box on my '01 F250 7.3. IMO, don't dump money into an alignment or anything else until you have the money for that steering gear box, and then have it all done at once.
Yes, supposedly Red Head has big and beefy yadda yadda yadda that was going to cost me 4 times as much for the box alone as it was purchased and installed from and at Ford themselves. Their customer service I found horrible as well. Only after I posted on this forum that I had called Red Head twice and left a message and after a few days still had not heard back did they finally call me back. Coincidence or not, a little too little and a little too late, IMO.
Old Aug 8, 2012 | 12:45 PM
SteveH-CO's Avatar
SteveH-CO
I would adjust play out of the OEM steering box (and get everything else under control - alignment, etc.) before replacing the steering box.
Old Aug 8, 2012 | 04:58 PM
planofootball19
thanks guys for all the replies! well after i posted this i went out to go check the tie rod's and other such things. My neighbor helped as i got in the truck and wiggled the steering wheel around. Bingo! we found that the inner tie rod connecting to the pitman arm i believe had way too much play, (forgive me if the names where wrong, im new to working on front ends!) So after a little bit of work we got the new one in. HUGE difference, the truck does not wonder half as much and the steering is much tighter. Upon inspection of the old inner tie rod showed that the joint was extremely loose. Went and got it aligned after that this morning and she drives great. I appreciate all the advice!
Jeff heine
Aug 19, 2023 09:42 AM
cdiesel
6.7L Power Stroke Diesel
Jun 21, 2017 08:35 PM
kbf1961
Oct 7, 2014 04:09 PM
DogDoc94
Nov 29, 2011 10:24 PM
SUPERDUTY OUTLAW
21
Jun 14, 2010 08:03 PM
