Quick radiator drain question
Old Aug 7, 2012 | 04:51 PM
Crew-it's Avatar
Crew-it
Just drained my radiator the final time in the flushing process. These rigs have a 29 qt system right? Which is a hair over 7 gallons. I'm only getting about 5 gallons out so there should be 2 more somewhere. Is there a way to get that last 2 gallons out without pulling freeze plugs? Is the content of the overflow tank part of the 29 quarts?
Old Aug 7, 2012 | 04:53 PM
Crew-it's Avatar
Crew-it
Oh, also, in filling the system back up, I've been fighting trapped air somewhere and can only get about 2 or 3 gallons in the system before it's coming out the top of the radiator. Does anything else need to be removed to allow air to escape while filling?
Old Aug 7, 2012 | 04:56 PM
kobaltblue's Avatar
kobaltblue
Start it and let it idol until the thermostat opens then finish filling, Just dont revv it... it will start puking fluid.
Old Aug 7, 2012 | 05:10 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
did you pull the two block drains on each side of the block near the rear of the engine?
Old Aug 7, 2012 | 05:18 PM
Crew-it's Avatar
Crew-it
Didn't know there were drains back there. Will go check it out. Thanks again Chiltons!!! Hate them sometimes. LOL
Old Aug 7, 2012 | 05:46 PM
Crew-it's Avatar
Crew-it
Found them and draining. Well, one is draining the other one gave me a bath. LOL
Thanks for the quick and great info. Appreciate it.
Old Aug 7, 2012 | 05:55 PM
'94IDITurbo7.3
no problem it is crazy how much coolant will come out of those when they are pulled.
charlescc
Mar 15, 2011 09:45 PM
stitch89
Feb 26, 2011 07:26 PM
twp
1997 - 2003 F150
Jan 30, 2008 08:24 AM
Mark62
Aug 18, 2007 11:24 AM
