well Im not mike....
I drop the ac compressor down. If you break the sensor wich is common to do then you will wind up either tring to get it out with a pick or pulling the pans
I will assume you are asking this question is because you intend on going ahead to replace your entire main engine wiring to correct the problem you are having as described in your other thread. That said, I'm not going to tell you any other way, other than the way I do it. And that is to remove the drive belt tensioner, disconnect the main ground on the lower right side (right meaning passenger side) of the engine. That will give you the space needed to disconnect the A/C compressor from the engine block as needed to route the CKP sensor wiring in its original routing. Ditto on the CMP sensor wiring. You may find it easier to remove the EBP sensor bracket and thermostat housing for better access.
tjustice what they are telling you is the easy part about the sensor . The AC compressor is a whole other job in itself , which requires fan removal . Get a air hammer just an early tip .
Should have been clear...Yes, I am just replacing the main harness. So what I am gathereing is disassemble of the front end of the truck, by removing the fan shroud, fan, AC compressor, groundwire, belt tensioner anything I have left out? Should have did whn I had all that off the first time...Who knew..... Thanks
I read something way back ago about a shim on the AC compressor some guys was removing.....While i am there, just thinking.....I cant remember exactly what the issue was though......
After 80-90K miles the clutch plate has worn so much that the air gap is sometimes greater than what the clutch magnet can overcome. By removing the spacer the clutch plate is back in spec. between .016 and .030. I just removed mine this weekend.
Yup, did all the work my self....No was not the first start up, it ran but developed a miss, when got to normal operating temps would shut off, then did the FICM and wouldn't start at all...That's when the wire hunting began. The oil cooler was full of water.
Well it should be Half full water/coolant and other half Oil
But Normaly it fails and pumps OIL into the Coolant Thus your Darker coolant
