The first 100 days...
Old Aug 6, 2012 | 10:26 AM
f150crewcab's Avatar
f150crewcab
Thanks to FTE, my first 100 days of X ownership were full of helpful mods. Here's what I did:
  1. Fuel Pressure "Blue" spring upgrade.
  2. New (OEM) fuel filters.
  3. HFCM: cleaned and upgraded plug to fix WIF light that was always on.
    HFCM Before:
    HFCM after. You can see the back of the new drain plug as well:
  4. Coolant filter (dfuser).
  5. Coolant flush and fill. Added Fumoto drain plugs to 2 engine block drains (F-108N). Used ~50 gallons of distilled water to get all of the old Gold coolant out. Used Restore and Restore+. Refilled with CAT ELC silicate free coolant (concentrate purchased from local CAT dealer).
    http://home.comcast.net/~lyon.family...ush%20v1-0.pdf
  6. New front and rear brake rotors and pads. NAPA Ultra Premium rotors on front with Hawk LTS pads. NAPA Premium rotors on rear with Wagner SD (Advance Auto) pads.
  7. Transmission flushed at dealer; replaced external transmission filter.
  8. Oil change with new (OEM) filters. Add Fumuto drain plug to oil pan (F-111N).
  9. New OEM air filter; replaced aFe filter from previous owner.
  10. New Rancho 9000XL shocks all the way around.
  11. Last but certainly not least: V/B spring swap. This thread helped me tremendously:
    https://www.ford-trucks.com/forums/1...p-by-step.html
    Complete before/after pics: https://www.ford-trucks.com/forums/1...l#post12063857 (post #78 from "step-by-step" thread linked above).
    The Rig Before the spring swap:
    The Rig AFTER spring swap:
Wish list:
  1. Gauges to monitor EGT, FP, BST, such as: https://www.ford-trucks.com/forums/1...ied-these.html
  2. Clean turbo (it throws a P0299 code under a load).
  3. Tighten steering box.
  4. Head gaskets/studs (not "required" yet, but...); fix/replace/upgrade EGR, Oil cooler, HPO screen/ STC fitting, stand pipe and dummy plugs.
  5. CCV re-route.
  6. Deal with some surface rust underneath with Fluid Film or similar.
  7. High idle mod.
  8. Electric cooling fan or Fan clutch override switch. 6.0 runs warmer than I'd prefer under a load. Discussion: https://www.ford-trucks.com/forums/1...hich-wire.html
  9. I'm sure this list will continue to grow...
Thanks to many on FTE for invaluable tips/tricks/advice. Reps sent.
brycez28
Feb 1, 2016 09:31 AM
FiznUKa
Jun 11, 2014 10:59 PM
dlibson
Jul 11, 2013 10:30 AM
snorindad
Nov 18, 2011 10:43 AM
Hand Clutch
Mar 3, 2011 07:44 AM
