clutch problems
Old May 12, 2003 | 12:27 PM
erk69's Avatar
erk69
clutch problems
HELP! new guy here, I have a 69 f100 3 speed tranny. I can't get it in to gear, my peddel stays on the floor and won't retract to its normal position. I looked at it and nothing seems abnormal like broken parts. any ideas?
Old May 12, 2003 | 03:42 PM
heep70's Avatar
heep70
clutch problems
Is the return spring still there? Can you manually return the clutch fork (not the pedal)? My guess is the pressure plate is taost.
Old May 19, 2003 | 09:06 AM
erk69's Avatar
erk69
clutch problems
Yes the spring is still there and yes I can return the fork, it well shift when engine is off. second question,how to tell a c4 from a c6 tranny? like i said i'm new at this.
Old May 19, 2003 | 09:37 AM
heep70's Avatar
heep70
clutch problems
Sounds like you need a new pressure plate, disk, and throw out bearing. The only thing that puzzels me is way the return spring itself won't bring the clutch fork back. How old is the pressure plate. I am still pointing my finger at that.
Check out this web page. You can see how to tell the two trannies apart. They are on the lower right corner of the page. The pan is the easiest way to see the difference.
http://www.turboaction.com/vb7.html
Old May 19, 2003 | 10:12 AM
millertime300's Avatar
millertime300
clutch problems
You clutch could be in backwards.
Your pressure plate could be loose on your fly wheel. Check to see if the pressure plate is loose first.
Try to find anyplace that the linkage is binding up, or badlyworn/ broke. Lube everything up well. Take off the dust cover if you have one and look for problems.
Old May 19, 2003 | 01:45 PM
erk69's Avatar
erk69
clutch problems
i found this[IMG]tr part[/IMG] pic wont show
Old May 19, 2003 | 07:56 PM
erk69's Avatar
erk69
Question clutch problems
well i looked again for broken parts and found that my pin(7a588 )was broke.my question now is, is this pin the reason my clucth is not wanting to engage, or does it just hold shifting arm linkage steady while shifting?
steve340
34
Aug 6, 2016 03:01 PM
Farmtruckn
Jul 31, 2015 01:10 PM
bill11012
Jun 14, 2009 10:54 PM
marks69
Jan 31, 2008 04:19 PM
gtex
May 2, 2003 01:47 PM
