Mirror help
Old Aug 5, 2012 | 01:49 PM
joerickson's Avatar
joerickson
Mirror help
If anyone has these style mirrors, I would love to see pictures of them on your truck. I believe they are called style 5. When I did all the body work and painted my truck I welded all the old mirror holes and dont want to put the common mirror style back on.
Here is a picture, not mine just found on google.
Old Aug 5, 2012 | 02:20 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Kit, mirror, type 5
Fits 73-up F100-350, RH or LH, Chrome, 4" X 5" (manual)
D3TZ-17696-L
Wesley Obsolete Parts, Liberty, KY has 3 (606) 787-5293
Antique Auto Arlington, Arlington, TX has 3 (817) 275-2381
There is also a remote control version for the drivers door.
D3TZ-17696-K
Unfortunately I couldn't locate any of the remote control versions.
Old Aug 5, 2012 | 04:10 PM
MAULMAUL's Avatar
MAULMAUL
LMC has them. You may be able to find them cheaper, but the part number is 49-6521. The listed price is 39.95 each.
Here is a picture of them on Pop's Truck before the rebuild began.
Old Aug 14, 2012 | 03:12 PM
Nseal1996's Avatar
Nseal1996
do yall know where i could possibly get west coast style mirrors
Old Aug 14, 2012 | 03:19 PM
montana_highboy's Avatar
montana_highboy
There's currently a couple sets on ebay...
67 through 72 ford truck f100 f250 stainlees west coast mirrors | eBay
1967 through 72 stainless west coast ford pu mirrors | eBay
Old Aug 14, 2012 | 03:27 PM
Nseal1996's Avatar
Nseal1996
wow why are they so expensive
Old Aug 14, 2012 | 03:35 PM
montana_highboy
Tell me about it , that's just the going rate on ebay, they always sell for around $200 on there.
I too am looking for a set of westcoast mirrors but i refuse to pay ebay prices for them.
My local yard will sell me a pair for $60 but i just need to wait for a set to come in, patience.
Old Aug 14, 2012 | 04:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 Western aka West Coast mirrors are not the same as 1967/72. The mounting brackets are different because the door contours are different.
And, 1967/72 & 1973/79: There are two different types. With or without the 3rd steady rest arm. 3rd steady rests have longer arms, so the mirror sticks out well past the cab.
Without the 3rd arms, the mirrors are "Swing-Loks" .. Push the mirror forward, then pull it back, it will lock into position.
The mirror head (C7TZ-17723-A) is the same for all. Genuine Ford: Has three vertical embossed lines, with the center line shorter than the other two.
1973/79: D3TZ-17696-L (reproduced) was the standard equipment mirror, resembles the type used on Passenger Cars.
C7AZ-17696-A was the 1967/72 F100/350 standard equipment version. This mirror (also reproduced) was installed on some cars.
Some repop sellers are calling these two mirrors by the idiotic name: Sports Mirror. FoMoCo never offered any such thing.
There were left & right remote control mirrors offered for 1967/72 F100/350's.
btw: Most people did not want C7AZ-17696-A or D3TZ-17696-L and none were factory installed, were placed inside the cab (in a plastic bag) at final aseembly. Dealers installed all the outside mirrors.
100's of 1000's of these mirrors were THROWN AWAY. Since they did not come in a parts carton with the part number on it, could not be returned to FoMoCo for credit, so the dealers were STUCK with them.
When I was at Crenshaw Motors, we had a huge wooden shipping crate full of these mirrors next to the moulding rack. When the rack was expanded, I threw all the mirrors into the dipsy dumpster!
Old Aug 15, 2012 | 02:04 PM
Blown 331's Avatar
Blown 331
Not the style you are looking for but they are genuine Ford and the price is right. I have a set on my truck and couldn't be happier wtih the purchase.
Mirror, Truck/RV, Ford, D4TZ-17696-AA | eBay
Old Aug 15, 2012 | 10:27 PM
joerickson's Avatar
joerickson
Not interested in that style, and I already purchased and recieved the mirrors I wanted from NPD.
Old Aug 15, 2012 | 11:53 PM
VocaTexas's Avatar
VocaTexas
Maybe Number Dummy can answer this mirror question...
There appears to be two styles of these mirrors. This is the only style I had ever seen come OEM until fairly recently:
But this style appears to have been OEM as well:
Was it simply a matter of which plant the vehicle came from, or something else?
Old Aug 16, 2012 | 02:54 AM
NumberDummy
Originally Posted by VocaTexas
Was it simply a matter of which plant the vehicle came from?
Assembly plants had nothing to do with it. All outside mirrors were installed by the dealers.
15 different types of outside mirrors were offered for 1973/79 F100/350's. FIFTEEN!
There appears to be two styles of these Type 9 mirrors.
When body shops/garages ordered replacement Type 9's, several questions had to be asked. Some shops didn't look, guessed instead. (sigh)
So, some mirrors had to be returned for the correct mirrors.
6 different styles of Type 9 Low Mount Swing-Loks:
1973/77:
1) D4TZ-17696-A .. Outside Mirror / 5 1/4" x 8 1/4" stainless mirror head / FLAT upper/lower mounting brackets / Upper bracket has (2) mounting holes on a 2 3/4" bolt center.
Lower bracket has (2) mounting holes on 2" bolt center / Arm has 7 19/32" span between upper/lower brackets / D4TZ-17723-A .. Mirror Head.
1976/77:
2) D6TZ-17696-A .. Outside Mirror / 5 1/4" x 8 1/4" stainless mirror head / CURVED upper/lower mounting brackets with 2" mounting holes.
Arm has 6 11/16" span between upper/lower brackets / D4TZ-17723-A .. Mirror Head.
1978/79:
3) D8TZ-17682-A .. Outside Mirror / 6" x 9" stainless mirror head / Mirror glass mounts to housing without a gasket / D8TZ-17723-A .. Mirror Head.
4) D8TZ-17682-D .. Outside Mirror / 6" x 9" painted low gloss black D8TZ-17723-D .. Mirror Head.
5) D8TZ-17682-E .. Outside Mirror / 5 1/4" x 8 1/4" stainless mirror head / Mirror glass mounts to housing with a gasket / D4TZ-17723-A .. Mirror Head.
6) D9TZ-17682-A .. Outside Mirror / 6" x 9" stainless mirror head / Mirror glass mounts to housing with a gasket / D9TZ-17723-A .. Mirror Head.
But...1978/79's could have 1973/77 mirrors...cuz dealers would install whatever they had in stock.
Today, 33+ years after the fact, any Type 9 could be installed on these trucks. When some FTE members have asked for these mirrors, I've had to ask the same questions I did 33+ years ago.
And then...there's this bug-a-boo: Similar mirrors were available from autoparts stores! Most are not Swing-Loks, none match the genuine Ford originals.
Old Aug 16, 2012 | 08:33 AM
VocaTexas's Avatar
VocaTexas
Thanks for explaining that, ND. That clears things up....I think...
Old Aug 16, 2012 | 12:13 PM
KingBigJoe's Avatar
KingBigJoe
Subscribed for future reference in case I need some new type 9 mirrors.
Old Aug 16, 2012 | 12:29 PM
NumberDummy
Just make sure you get the type that the upper/lower mounting brackets match the holes in your doors.
ebay link in post 9: D4TZ-17696-A ~ 30 bucks each is a roaring bargain! Last MSRP each: $98.00 / Dealer cost each: $65.33.
No Ford Dealer obsolete parts vendor has any.
D6TZ-17696-A = Last MSRP each: $58.33 / Dealer cost each: $35.00.
16 available NOS from 12 FoMoCo Dealers / 2 available from 2 obsolete parts vendors.
