All This Charging System Talk...
Sarge
so, if you are running #1 cable for the +12, you need the same,
or a ground braid strap with the same cross sectional area.
a 3/4" wide strap is plenty.
batteries will only take current so fast, but let's say you
have a battery that will take 100 amps charge rate,
and you have two in parallell, so that is 200 amps
load from the batteries..... now, your batteries are low,
and you start up the truck, you have glow and all the cold
engine loads, which i believe is around 100 amps....
now, you have a stereo on, and it's pulling 50 amps.....
trust me, a strong stereo can pull four times that amount...
just driving off to work one cold morning with your sippy cup
of coffee, listening to blind faith, you are pulling 350 amps,
but you are limited to 250 amps or whatever your alternator
is rated for....
so your ground lead is pulling 250 amps, as the batteries make
up the difference between your load, and your generating capacity.
and that is going thru your ground cable.
212 amps will burn a #12 copper wire in half, fuse it.
it'll heat up a #4 wire, smoking hot.
more bigger wire, and turn down that damn stereo!
Also if anyone could steer Mark(Bismic) to this thread, or anyone else that has done the wire upgrade, to post pics of how you ran the power wire. I did mone temp. so I could use the truck this weekend but I dont like it, soIm interested to see what you guys did.
All in all this is a great unit and well worth the money as well. I drove the truck Saturday and the voltage never dropped below 14.5 or so, and I had pretty muc everything on except the wipers.
Anyone thinking twice about this upgrade...dont just do it.
Sarge
Basically the ground cable they supply is only good for the drivers side ground terminal. The ground terminal on the passenger side has a few branches that go from engine block to frame as well as to the body on the topside.... I had one made up but it's not necessary. The ground cables on these trucks (at least on mine) is already a 1 gauge cable. The main power wire however coming off the alternator looks like 4 gauge so it definitely needs to be changed out (provided with fuse in the upgrade kit you have). The other cable I would upgrade is the positive lead cable that goes from battery to battery.... it is also 4 gauge. I upgraded this to a 1/0 as well.
Nice cable they send in that kit huh?
Here's a link to a thread with some pics of mine.
https://www.ford-trucks.com/forums/1...more-pics.html
Thanks for the links,
Reps your way,
Sarge
Reps your way,
Sarge
I believe you had said you got the wire upgrade kit from DC Power.... it comes with the main lead along with a fuse. Is there any reason why you chose not to use it?
Remember, it is not "necessary" to change the grounds as they are already 1 gauge from factory.... the main power supply from alternator must be changed to either a 1 AWG or 1/0 at minimum. Some say you don't need to worry about the battery to battery positive lead but I changed mine to 1/0 anyways to match the main charge cable.
Just to clarify I did use both the OEM charge wire, the upgraded charge wire, and fues assembly.
Sorry I confused everyone.
Sarge
Sarge
