electrical problems
Old Aug 4, 2012 | 11:12 PM
dpatterson200544's Avatar
dpatterson200544
electrical problems
im new to this web site im having problems with lights it keeps burning the light switch and the plastic block the wires go in to the light switch everthing work fine until i turn the lights on left blinker wont work transmission want go into overdrive when lights are off parking lights come on when i press the brake pedal anyone have any ideal whats wrong im thinking brake light switch or could it be the switch on brakecylinder there is a recall on it
Old Aug 5, 2012 | 07:49 AM
Talyn's Avatar
Talyn
Sounds like you have a short in the stearing column.
The ford light switch is a full route, so it has all 14 volts, so if there is a short in that system, it will take the load.
Check fuses in the box under the hood, blinker fuses are there.
Then youll have to check in stearing column,
Guys have had these issues with pinched wires and tilt columns.
If you want to eliminate the brake sensor, just unplug it.
Old Aug 5, 2012 | 10:57 AM
dpatterson200544
thanks for the info this would happen when my inspection sticker just expired when the lights are on the brake light on cab is on its like i have my foot on brake but i dont
Old Aug 6, 2012 | 06:32 AM
DIYMechanic's Avatar
DIYMechanic
Yeah I t sounds like you have a short in the system some place. That will cause all the issues you're describing.
Here is a link that may prove useful to you:
1996 Bronco/F-Series Workshop Manual
This is a link to the manual for our trucks. Go to the site, then click on the Lighting Tab on the left hand side. Inside there, you can either select exterior or interior and then there are a bunch of links that will come up. I would start by taking the covers off the steering column though. Talyn is right that is a very good place to start looking since it isn't at all uncommon to have wiring issues inside the tilt column if you use it a lot.
Old Aug 6, 2012 | 08:03 AM
fordpride's Avatar
fordpride
Post 52 has a lot of wiring diagrams
https://www.ford-trucks.com/forums/1...o-links-4.html
Old Aug 11, 2012 | 03:55 PM
dpatterson200544
electrical problems
thanks alot for the wiring info i think its the keyless remote shorting out the tan and white wire that keeps burning the light switch up goes to the keyless remote now all ive got to do is find the darn thing
Old Aug 11, 2012 | 04:01 PM
ReBilld's Avatar
ReBilld
It's under the dash almost straight above the fuel pedal. It's a black box with a lot of wires coming out the bottom. If you take the lower part of the dash under the steering column off, you're looking right at it.
Old Aug 11, 2012 | 04:13 PM
dpatterson200544
remote keyless entry
do you think the windshield leaking would cause this problem
Old Aug 11, 2012 | 07:47 PM
dougbrown's Avatar
dougbrown
Yes it could, Water and eletrical parts dont mix well.
Roger T. Pipe
Jun 25, 2013 06:57 PM
srauner
Electrical Systems/Wiring
Oct 30, 2012 07:53 PM
trinogt
May 20, 2002 11:45 PM
rumblinbass
Nov 14, 2001 09:42 PM
Nov 8, 2001 06:55 AM
