Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
help with vin F700
Old Aug 3, 2012 | 10:40 PM
highspeedblowout's Avatar
highspeedblowout
help with vin F700
hopin ND will will help me to confirm year on my F700. Tittle says 1980. VIN is F70EVC41586
Old Aug 6, 2012 | 11:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by highspeedblowout
hopin ND will will help me to confirm year on my F700. Title says 1980. VIN is F70EVC41586.
Where did you get this VIN from? Hidden on the frame rail or off the Warranty Plate?
Peeps replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plate on the replaced door.
F70 = F700 (gas).
E = 361 2V or 4V FT engine (same E code used for both 1976/78).
V = Kentucky Truck Assembly Plant.
C41586 = 1976 (1976 serial number range: A10,001-D25,000).
FT engines not installed after 1978, have 5 valve cover bolts per side.
370/429 introduced in 1979, have 7 valve cover bolts per side.
Old Aug 6, 2012 | 08:52 PM
highspeedblowout
thank you numbers guy. The title says 1980. I keep comin up with the wrong parts.
67c850
Large Truck
Jan 28, 2019 12:16 PM
allis327
Large Truck
Apr 13, 2015 06:20 AM
Nobby
Dec 10, 2011 10:51 AM
66-Ol'Henry
Oct 20, 2011 05:16 PM
Henry Carter
Aug 31, 2010 07:18 AM
