VIN
Old Oct 19, 2011 | 09:33 PM
66-Ol'Henry's Avatar
66-Ol'Henry
VIN
Does anyone know where I'd find the vin on my truck
Would it be the warranty number? I looked in the book for something but no luck
Old Oct 19, 2011 | 11:14 PM
Bill W's Avatar
Bill W
Vin is stamped on the top of the frame.... left side under the cab and about where the statrer is located. Your Warranty plate should match the vin which should match the title.
post the numbers and someone here can decode it for you.
Old Oct 20, 2011 | 02:24 AM
camperspecial65's Avatar
camperspecial65
the VIN is stamped on the topside of the passenger side frame rail approx. 12" in front of the engine crossmember. Its also under the cab as noted prior.
On Canadian built trucks its in same locations, but on driver side frame rail.
The characters are approx 1/4" tall and the VIN is bookended with asterisks...
It would look like this *F25DR123456*
Warranty number is same as VIN
- cs65
Old Oct 20, 2011 | 04:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Canadian VIN's (Ford/Mercury trucks assembled and sold new in Canada thru 1965) are unique to Canada only. 1965 example: 4991014L-123456A
The 1965 and prior years Canadian Warranty (Rating) Plate and the codes stamped thereon are also different than US trucks.
This plate will be found on the left (drivers) side A piller (windshield post), visible when the door is opened.
1966/68 Canadian VIN's, Warranty Plate/codes are the same as US trucks.
This Warranty Plate is located on the left door face, below the latch (ditto 1963/65 US & 1969/80 US trucks).
FoMoCo vehicles: Since 1948 (trucks), 1949 (passenger cars) the entire vehicle is registered by the VIN, so it will be found on the registration/title.
Prior years, vehicles were registered by their engine numbers. The problem was, if the engine was changed, the numbers no longer matched.
Old Oct 20, 2011 | 10:04 AM
66-Ol'Henry
okay, here is my VIN
F10YD874443
tell me whatcha got
Old Oct 20, 2011 | 03:46 PM
The Masked Rider's Avatar
The Masked Rider
What are the rest of the #s below that?
Old Oct 20, 2011 | 04:28 PM
66-Ol'Henry
thats the VIN lol. number dummy desiphered it for me already
Old Oct 20, 2011 | 05:16 PM
NumberDummy
FTE has been having server problems today. I decoded the puppy three times...hours ago, but...none of the posts showed up. Gave up, sent the OP a PM with the info.
F10YD874443 // F10 = F100 2WD / Y = 352 2V / D = Dallas TX Assembly Plant / 874443 = 1966, assembled June 1966.
Originally Posted by The Masked Rider
What are the rest of the numbers below that?
Fritz is referring to the codes found on the Warranty Plate, because he assumed the VIN was taken from it.
The VIN is on the first line, the codes are on the 2nd and 3rd lines.
allis327
Large Truck
Apr 13, 2015 06:20 AM
1972RedNeck
32
Nov 18, 2013 09:56 PM
earthquake68
13
Apr 30, 2012 08:59 AM
Nobby
Dec 10, 2011 10:51 AM
Henry Carter
Aug 31, 2010 07:18 AM
