c6 tranny problem
Old Aug 2, 2012 | 05:43 PM
Daves94vert's Avatar
Daves94vert
c6 tranny problem
Finally got the truck running great. 1 day later, tranny's giving me problems. It won't shift out of first in drive but if I manually shift it 1-2 it works. Any ideas? Is there any way to test a tranny out of a truck( going to look at one on Saturday). Thanks.
Old Aug 2, 2012 | 06:22 PM
Wagonboy's Avatar
Wagonboy
Kickdown rod is stuck? Look to see if it is stuck in the "down" position, thus making the trans think you want "passing gear" all the time?
Old Aug 2, 2012 | 06:25 PM
Twistedwrench's Avatar
Twistedwrench
Junk in the valvebody .
Drop the pan , remove the valvebody and inspect the valves and bores for wear .
Keep everything in order !!!!
Old Aug 2, 2012 | 07:24 PM
Franklin2's Avatar
Franklin2
There is a vacuum line that connects to the modulator valve that is located on the pass side rear of the tranny. Make sure this line is hooked up and has engine vacuum on it.
Old Aug 2, 2012 | 07:45 PM
Gary Lewis's Avatar
Gary Lewis
Could be. I had a similar problem after the truck sat for a couple of years. But, a dose of Sea Foam tranny cleaner worked wonders. It took over 500 miles to get fully "automatic", but it started getting better within just a few miles. Lots easier than dropping the pan. LOTS. And, it is cheaper as you don't have to replace all the fluid, but maybe you should do that anyway?
Also could be. But, I thought that just modified the point that it shifts awa how it shifts. Still, something to check.
Old Aug 2, 2012 | 07:59 PM
arctic y block's Avatar
arctic y block
I like Lucas better than Seafoam. And x2 on the modulator being unhooked or just plain worn out. First I would check the kick down by disconnecting it and trying it again.
Old Aug 2, 2012 | 08:04 PM
Twistedwrench
All true guys , I just like to get an idea of what's going on internally in the tranny ....pulling the pan does that ( obviously )
Old Aug 2, 2012 | 09:03 PM
Daves94vert
I just went outside and had a look. It's definitely the kickdown. It's stuck. I unhooked the linkage from the carb. It's definitely stuck. Any ideas on how to unstick it. I just replaced the carb and forgot to put the spring back on it( I wondered where the spring came from. Again, thanks guys.
Old Aug 2, 2012 | 09:32 PM
1983F1503004x4's Avatar
1983F1503004x4
A bottle of WD-40? PB Blaster? Liquid wrench?
Heat? Gear oil? Heat and water? Some more heat?
A lot of prayer and cussing? A BFH?
I saw a truck pulling a car down the road with a 10000 LB tow strap the other day, had a guy in the back turning the wheel and pushing the brake pedal. If they can rig up something that redneck to pull a car down the road, imagine what I could do?
Let's take a Warn wench and connect to your kickdown linkage and give it a tug and see what happens.
Or, we could use a log chain to my D-rings on the back with a drag-style launch in 2nd gear?
Old Aug 2, 2012 | 09:45 PM
Daves94vert
So you're saying I should force it? The kick down has play in it, just in the wrong direction.
Old Aug 2, 2012 | 09:49 PM
1983F1503004x4
NO. No no no no no. Sorry if I made you think that. I was trying to make a joke.
Play with it a little bit and see what you get. Lubricant can't hurt. You might even have to take the linkage apart (assuming you can, I haven't messed with the linkage on an auto).
You can drive the truck with the kick-down linkage detached. Take it for a drive and see how the transmission will shift. The kick down linkage mechanically "kicks-down" the transmission to a numerically higher gear when you put your foot to the floorboard, so you can get your RPM's up quicker and put the motor in its power band faster. This means quicker acceleration.
If you drive it with the linkage detached, make sure you don't lose anything that might be loose.
Twistedwrench
So the kick down will move up on the side of the tranny but not spring down and back ? Sounds like the kickdown linkage came out of the valvebody ?!
Old Aug 2, 2012 | 10:02 PM
Daves94vert
The kickdown is completely engaged. I can engage it a little more physically but it hits a brick wall trying to bring it to its rest position. I don't know much about granny's and have never worked on one. So please be patient with me. This is just a haul/tile work truck handed down from my dad and not my primary truck. Trying to keep my 07-150 as nice as I can as I'll have it a looong time. Thanks again.
Old Aug 3, 2012 | 06:19 AM
80FlareSide's Avatar
80FlareSide
If I remember correctly there is an actuator rod on the top of the valve body with a cut in it that the kick-down lever is supposed to rest in. I believe it may be possible to install the valve body incorrectly the the lever not resting in the cut. If that is the case, the rod could be binding on the k/d lever.
Other than that, I cant think if anything in the trans that the k/d could hang up on. While I am a huge fan of my BFH, I dont think this is a situation where you want to try and persuade anything loose just yet. I would, in this order:
1) Buy C6 Rebuild book or shop manual (there is someone that sells these on Ebay now in a full search-able PDF format.)
2) Buy drain universal drain plug kit
3) Drill 1/4" hole in side of pan where you want plug to later go
4) Drain off nearly 2 gallons of ATF through hole
5) Remove pan
6) Remove valve body
7) See if k/d is now free
8) If free put valve body back in, hopefully all is solved. If not free, I have no clue - Maybe time for the BFH.
Old Aug 3, 2012 | 10:46 AM
TheKirbyMan's Avatar
TheKirbyMan
BFHs and transmissions don't mix...if it's hanging up, there's gotta be a reason for it!
If you're not shifting out of first, make sure the modulator valve (small metal vacuum can on bottom right of transmission, looking at it from under the truck behind the transmission) is getting vacuum. Without vacuum, you won't get an automatic shift, but you can still manually shift.
Also check the vacuum line that runs from the engine to the modulator valve doesn't have any transmission fluid inside it. If it does, your valve is damaged and needs to be replaced (very simple job, held in by one bolt).
