driver side fender stud
Old Aug 1, 2012 | 10:45 PM
jerryst's Avatar
jerryst
On my 1955 f100 I am putting back the front fender. There is a stud on the fender that acts as a locator. I never had a nut on that bolt. does anyone know the thread size of this stud? Thanks for any information.
Jerryst
Old Aug 2, 2012 | 07:35 AM
raytasch's Avatar
raytasch
Believe Nothing
Go buy a 5/16" fine and a 5/16" course thread nut. One of them will work. Don't forget a washer.
Old Aug 2, 2012 | 07:55 AM
sdetweil's Avatar
sdetweil
Jerryst
shouldn't be a stud.. I had one on one of my fenders.. some WD and a vice grip broke it loose and let me remove it, run a tap thru the hole.
all the stock bolts, are as noted, 5/16 24 fine thread
three each from the inside of the cab
one up from the outside thru the fender wraparound
Sam
Old Aug 2, 2012 | 08:19 AM
raytasch's Avatar
raytasch
Believe Nothing
Now this is interesting, perhaps an assembly plant variation. My '56 had studs in the one position of each side. From what I found, I don't think either fender had ever been off the truck.
Old Aug 2, 2012 | 08:42 AM
sdetweil's Avatar
sdetweil
hm.. never seen a stud til this last truck. have disassembled 4 that I believe we never modified. this is the 1st 56 tho.. (only one side had it)
I know the truck was disassembled before, and based on the other cootybob hacks done, I 'assumed' this was a prior owner action.
Sam
Old Aug 2, 2012 | 09:00 AM
CharlieLed's Avatar
CharlieLed
I have seen a few fenders with "studs"...turns out that the bolts were frozen into the anchor nuts in the fender and when the person who disassembled the truck took the bolts out they spun the head off the bolt. Voila, a stud. I have never seen a stud used from the factory, not to say it hadn't ever been done, just that I haven't seen one.
Old Aug 6, 2012 | 12:52 AM
jerryst's Avatar
jerryst
it turns out it was a 5/16 course stud. it just had a lot of rust. thats why nuts i had would not work.
jerryt
Old Aug 6, 2012 | 03:53 PM
3golfjack's Avatar
3golfjack
If it is a 5/16-18 instead of a 5/16-24 that could had been a contributing factor to why it may of froze and snapped off at the end. Just about everything on these trucks which is 5/16 is fine tread.
Oldschool2888
Mar 4, 2018 09:44 AM
fastman35
17
Apr 17, 2015 10:54 AM
flamesoldier
19
Mar 18, 2013 01:57 PM
dorideher
Jul 18, 2010 05:16 PM
comet
Mar 7, 2005 01:49 PM
