Shift-Knob Button
Old Aug 1, 2012 | 10:59 AM
Strko75's Avatar
Strko75
Shift-**** Button
Vehicle: 2007 Explorer Sport Trac V8 Limited (no warranty or extended warranty remaining)
Problem: The shift-**** button appears to be loose, or doesn't have the ability to be depressed completely to allow for a smooth shift between gears. It hasn't locked up, but I am very conscious of how much pressure I exert on the button to make sure it shifts.
I have heard there is a TBS solution (doesn't apply to me with no warranty), I have also seen a YouTube video that removes a black piece within the shifter mechanism (when you depress the brakes, its clicks), but I am not sure this is the root cause of the issue.
Anyone experience such problems, and have a DIY solution? or do I have to bring it in to the mechanic?
Thanks.
Old Aug 1, 2012 | 01:09 PM
shorod's Avatar
shorod
Welcome to the forum!
I want to make sure we understand what you are talking about here. Does your Sport Trac have a column shifter or a console shifter? The description leads me to believe console, but I thought only the Aviators had that.
If column shift, are you referring to the "OD Off" button on the end of the shifter? If yes, then the shift interlock that releases when you press the brake pedal would not have anything to do with that.
Also, a Technical Service Bulletin (TSB) could still apply to your truck, but since you're out of warranty a dealer or shop would charge you money to implement the TSB solution. TSBs are generally just typical fixes for rather common issues. When such "common issues" are deemed to be safety concerns, then they may become recalls. In the event of a recall the warranty period typically does not matter.
-Rod
Old Aug 2, 2012 | 06:49 AM
Strko75's Avatar
Strko75
My ST has a console shifter with an O/D on/off button located near the bottom of the leather shifter(which is not the issue, and is working fine). It's the actual large button that allows you to move freely between gears, appears to to have the issue OR it's the black plastic part that's located underneath the console of the shifter.
Hope this helps.
Bluovlnut
Crossovers
Dec 30, 2015 11:12 AM
sithot
2009 - 2014 F150
20
Nov 9, 2011 06:56 AM
bookem15
6.7L Power Stroke Diesel
15
Nov 22, 2010 11:48 AM
powerstroke1350
Jun 30, 2008 03:05 PM
LACityFD
2004 - 2008 F150
Oct 16, 2007 04:43 PM
