Will this transmission bolt up?
Old 07-31-2012, 06:47 PM
Delano Teslik's Avatar
Delano Teslik
Delano Teslik is offline
Okay, I have a 1979 ford f-150 2wd with the 400m v8 engine and an automatic transmission, right now my truck has a 1976 c6 transmission in it, and sadly it has finally failed me. So I called my local junk yard, he said he had a 1973 ford drive in with a c6 in it, my question is, will the 73' c6 bolt up to my 79 400m? answers would be greatly appreciated!!
Old 07-31-2012, 07:09 PM
crsmiffy's Avatar
crsmiffy
crsmiffy is offline
Depends what the engine was bolted in the 73. If it was a 429-460 it should be okay, the only difference being a different bearing snout on the torque convertor. If it's a 351C, (did they run these on that model?) than that is very likely to be a small block pattern like the windsors so no go there.
The only other way to be different is if you had the rare as unicorn excrement small block pattern 400. Seemed to have found their way into cars as the story goes and usually had a FMX behind them so realistically this shouldnt be an issue unless someone had a real good play with it before you. Good luck.
Old 07-31-2012, 07:36 PM
J ballan's Avatar
J ballan
J ballan is offline
I believe the 360, and 390s had a different bellhousing also.
Old 08-01-2012, 03:46 PM
400 .040over's Avatar
400 .040over
400 .040over is offline
any auto trans from the 385 series will work with the 400
Old 08-01-2012, 05:46 PM
wyoming4x4's Avatar
wyoming4x4
wyoming4x4 is offline
question on tail shaft!
If i remember correctly some tail shaft are different. most are standard. I run 4wds but 2wheel drives believe their was 2 setups? definelty take a tape measure. torque converter a little different. check converter thrust once installed. if pulled to far forward you pull the converter out of the internal pump in tranny, want about 1/8" of play at most at converter.Sometimes have to shim converter to get proper converter set. i believe their is something different on 400 converter compared to 460/429. i'm forgettin stuff but remember it when i'm doing the job. hope i didn't confuse you but got me scratching my head a little myself. haven't had a auto tranny C-6 problem in a long time.
Dustin
12-07-2010 09:10 AM
460man
12-07-2005 09:48 PM
Clay911
03-09-2004 09:28 PM
41Clay
01-28-2003 09:32 AM
78blueford
01-06-2003 08:56 PM
Quick Reply: Will this transmission bolt up?
