Good Evening Everyone!, Im Fixing to change my driverside rear caliper, and im wondering what to expect and maybe a general idea on how to replace it. Any Help, advice and hints would be great, thanks in advance
I replaced all four of mine this summer. Purchase a rebuilt unit that includes the caliper bracket also. Many times the slider pins are frozen in the bracket. The removal is pretty straight forward. Two bolts to remove the caliper and two bolts to remove the caliper bracket. The parking brake shoes apply inside the rotor. The inside of the rotor is basically a drum. If your parking brake works properly all they need is a cleaning with some brake cleaner. When you get it all back together, now is a good time to flush the brake fluid in the entire system.
