REPLACE WATER PUMP OR NOT ????
Old Jul 31, 2012 | 04:26 PM
wulfman's Avatar
wulfman
Okay got fan , stator , and shroud off to do AC compressor . And want to say that after reading threads on fan removal that took people forever i was worried about tackling it . But i did it the CHEEZIT way with a air hammer ( cost only 15 bucks ) and it made short work of it . I could do it all in 20 min now . So back to ?? water pump is right there 10 years old and 166000 should i replace it or wait for it to go on its own ?
Old Jul 31, 2012 | 05:15 PM
tjustice's Avatar
tjustice
I was same place you are, I did with 85,000 miles. If your luck is like mine, next week water pump will go out....just my 2 cents....
Old Jul 31, 2012 | 06:05 PM
cheezit's Avatar
cheezit
if you do please make shure you get the correct one. also as a note I personly have had lots of issues with 03/04 replacment water pumps from ford. IMO I would get one with the steel impeller on the early pump.
Old Jul 31, 2012 | 06:20 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I don't think there's a right or wrong answer on that one.
Cons:
1. "I'm still Rollin with my original ....." and you could add water pump to the list.
2. Less expensive to leave it.
3. Only take 20 min to get to it.
4. you'll have a future use for your new air hammer.
5. Less chance of skinning a knuckle.
6. Finish current job quicker.
7. If it ain't broke.......
8. Consider it a "test" and see how far it will go.
9. Won't have to worry if the new one is good quality.
10. Impress the wife (or girlfriend) with lower total bill for current repair.
Pro's:
1. You're right there, just knock it out.
2. It will probably fail soon anyway.
3. Be interesting to see if it has plastic impeller.
4. Coolant is drained already.
5. Will be saving the time it takes to pull it back apart.
6. Shiny new metal parts look good.
7. Good chance to check front cover for cavitation.
8. Impress wife (girlfriend) with skill and knowledge.
9. Piece of mind (pumps in good shape- not gonna crap out on the road)
10. Ummm........
Old Jul 31, 2012 | 06:33 PM
wulfman's Avatar
wulfman
Cheezit what exactly is the correct one ? last time i put in thremo found little pieces of what looked like black plastic in there . Is this pieces of my water pump impeller .
Old Jul 31, 2012 | 06:34 PM
wulfman's Avatar
wulfman
Cons:
Pro's:
10. Ummm........
Rusty they both look tempting but thinking new pump .
Old Jul 31, 2012 | 06:47 PM
Piolet's Avatar
Piolet
Hey David,
I'm running an '03 with the original front cover. I changed my water pump recently and went with a reman from NAPA for about $40.
The reman did have a metal impellor and it came with an o-ring that fit perfectly.
No issues yet and from the stock photo and some other info on their website it looks like it is the same as the O'Reillys version.
Old Jul 31, 2012 | 07:00 PM
Piolet's Avatar
Piolet
Sorry I see that your question was "do it or not?"
Here's what I went through ....
Replaced fan clutch. 1.5hrs and 70 miles later I was dumping coolant. Radiator had cracked at the plastic. Installed new all metal Bullet proof diesel radiator. Drove the truck next day got home and new coolant leak coming from water pump. Replaced it with Napa part.
Right now I can get to that pump in 15mins but for $40 I would do it now so as not have to mess with it again. My $0.02.
Old Jul 31, 2012 | 07:08 PM
Rusty Axlerod
Me too.
____
Old Jul 31, 2012 | 07:14 PM
Misky6.0's Avatar
Misky6.0
Be a rebel. Change serpentine belt too!
Lower and upper radiator hoses too.
murphy's law ya know.
Good luck.
i 'm building up parts s i can do stuff in batches like this.
Old Jul 31, 2012 | 07:23 PM
69cj's Avatar
69cj
I agree with Misky, anything high mileage while your there do it. If not you'll be back soon and hopefully not on the open road during vacation.
Old Jul 31, 2012 | 07:26 PM
Piolet's Avatar
Piolet
+1 should have noted I did my belt too when I was there.
I wiped the old belt with belt conditioner and stuck it under the back seat in case of emergency.
Old Jul 31, 2012 | 08:13 PM
wulfman's Avatar
wulfman
Yea will do new pump . Hoses are new but will do new belt also . Thanks guys .
Old Jul 31, 2012 | 08:28 PM
cheezit's Avatar
cheezit
with out look at at IDK
Old Jul 31, 2012 | 08:32 PM
Yahiko's Avatar
Yahiko
I agree.
If it is one of those things that get replaced every now and then.
Like the belt. upper, lower hoses and T-stat. I would replace it and the
pump falls into that club.
Also things like U-joints,spline grease, front ,read differential oil,
Transfer case oil, Coolant and the filter the list goes on.
How ever you are the one that has to pick at what point do you
stop and drive it.
Sean
