Sponsored by: Real Truck
4wd Issue
Old Jul 30, 2012 | 11:09 PM
D.Herrmann's Avatar
D.Herrmann
4wd Issue
Need some opinions. My 2000 F-250 V10 will not go into 4wheel low or high. Once you switch into low you can feel the transfer case switching over but I jacked up my truck and noticed only the back two tires were spinning. The driver side axel was spinning but not moving the tire while the passenger front axel and tire were not moving. I do realize I do not have positive traction in the front but could the driver side axel to tire issue just be a bad hub?
Old Jul 31, 2012 | 05:42 AM
redford's Avatar
redford
FTE Leadership Emeritus
D.Herrmann, welcome to FTE!
1. You have a bad hub. Replace one or both.
2. The front differential will send torque to the axle spinning the fastest. You just proved that.
Old Jul 31, 2012 | 08:43 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Did you try to turn the hub to lock and see if they work that way? You may have a vacuum leak.
Old Jul 31, 2012 | 08:57 AM
D.Herrmann's Avatar
D.Herrmann
Tried hub both in Auto and in Lock individually both did not fix the issue. I'm right there with you guys I think it's a bad hub or vacuum leak
Old Jul 31, 2012 | 09:17 AM
miller_feed
If the hubs didn't lock in the lock position, it's the hubs as long as the transfer case is switching. Give this a try. I do this every year. Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Jul 31, 2012 | 11:18 AM
D.Herrmann's Avatar
D.Herrmann
Is it possible the hub is ok but just the locking mechanism (auto & lock) is the broken part? The hub looks to be in decent shape
Old Aug 3, 2012 | 01:33 PM
D.Herrmann's Avatar
D.Herrmann
replaced the hub and 4wd works great. I am now getting a clicking sound and sometimes vibrating feeling coming from the same side/wheel. I was told it was a bad bearing, the knuckle is loose and can be shaken but I am not sure what to purchase to replace that bearing. Thoughts? I have a 2000 F-250 4x4 V10
Old Aug 3, 2012 | 01:48 PM
miller_feed
Does the clicking stop when you put the truck in 4x4?
Old Aug 3, 2012 | 06:39 PM
D.Herrmann's Avatar
D.Herrmann
It does not do it in 4wd. Heard it might be an axel bearing?
Old Aug 4, 2012 | 08:14 AM
miller_feed
I think the needle bearing need to be greased. Here is how to do this. Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page.
Let us know how it goes.
Kemicalburns
Dec 19, 2016 02:20 PM
Steven Stocki
Dec 4, 2016 08:01 PM
KRH1326
1983 - 2012 Ranger & B-Series
Feb 11, 2013 06:15 PM
wcastle
Mar 14, 2011 08:54 PM
kenneBF250V10
Oct 25, 2010 12:14 PM
