Currently working on R&Ring the starter in a 2002 Ford Explorer Sport Trac, Manual 5 spd., 4.0L, 4x4
Seems to be not enough room to remove the starter through the bottom or the top. Just curious if removing the front driveshaft would give you enough room to pull it out. Im seriously hoping the whole front axle assy. doesn't get dropped.
