1953 Dashboard Accessories
Old Jul 30, 2012 | 01:23 AM
bigdaddylove's Avatar
bigdaddylove
Hi,
In what order were the original dashboard accessories (starter, lights, washer, heater, choke and throttle) placed? I did a search but found nothing that jumped out at me.
Also, what was the throttle used for? How does it differ from a choke?
Thanks in advance!
BDL
Old Jul 30, 2012 | 02:17 AM
old ugly's Avatar
old ugly
Originally Posted by bigdaddylove
Hi,
Thanks in advance!
BDL
I believe from left to right you should have the ignition switch, bottom, and light switch, top, on the left of the column then the wiper switch, choke and throttle on the right, not sure if it's choke then throttle or other way around. The heater controls go under the dash about the right middle. thier order depends on if you have a fresh air heater or a recirculating heater. Fresh air has four controls, a recirculating only has two. The fresh air controls from left to right, blower, temp, air and defrost. The recirculating, blower and I can't remember what the push pull **** was for, I would need to look at one of my controls to find out.
Old Jul 30, 2012 | 10:29 AM
raytasch's Avatar
raytasch
Believe Nothing
Hi,
Thanks in advance!
BDL
Most all vehicles of this era and earlier had hand throttles. The throttle could be used as a variation of cruise control. Flat level roads with no change in load, it worked, almost.
The throttle could also be used to bring the engine speed up for battery charging while the vehicle was stationary. It could be used to help speed engine warm up. (??) Some of these old trucks had PTOs that ran devices that required engine speeds above idle and for extended periods. Probably other reasons too but these come to mind.
The choke function is to enrich the fuel/air mixture for starting a cold engine. As a function of the choke, the idle speed is also increased. The engine should never be run for any extended time with the choke pulled.
While I am here, I'll tell a short story:
Years ago a woman bought a new car and the car delivered terrible gas mileage. Repeated trips to the dealer found no problem. I forget the exact punch line but anyway she told the service writer that that "cute little **** with the C on it made a great place to hang my purse when I pull it out ". End of gas mileage problems.
HTH
Old Jul 30, 2012 | 10:44 AM
53 tonner's Avatar
53 tonner
From left to right, I have the starter button, wiper, lights, steering column, throttle, choke, ignition key, and the lighter. The heater controls are on a separate panel below the dash.
Raytasch gave you a good explanation regarding the throttle and choke. My truck has a PTO driven hoist and when I had a heavy load in the box I would pull out the throttle to speed up the RPM's and pump more hydraulic oil through the hoist to lift the box. I used the throttle when the engine was cold too.
Gran
Old Jul 30, 2012 | 09:04 PM
old ugly's Avatar
old ugly
Gran
Ooops - Your right, I was thinking 56.
Old Aug 2, 2012 | 08:42 PM
bigdaddylove
Great, thanks everyone. All the info helps!
ftrk66
Mar 6, 2019 07:47 AM
can0fspam
Mar 22, 2018 12:26 PM
Adam Woolridge
Nov 29, 2015 08:27 PM
fordf350camper
Oct 13, 2008 10:12 AM
Kenny
Aug 24, 2000 09:40 PM
