Leveling the cab floor.
Old Aug 1, 2012 | 07:33 PM
turnrjr's Avatar
turnrjr
What have you guys done, if anything, about the cab floor ribs (depressions) prior to insulating & sound proofing. I see that Mid Fifties sells some sort of filler.
Old Aug 1, 2012 | 08:47 PM
52 Merc's Avatar
52 Merc
What are you concerned about exactly?
Old Aug 1, 2012 | 09:12 PM
Mervy49's Avatar
Mervy49
Not going to do anything about the depressions. The more junk you jam into them the more rust you invite. The depressions aren't in an area were they present a problem. JMO.
Old Aug 1, 2012 | 09:13 PM
CharlieLed's Avatar
CharlieLed
I have welded in 1 inch wide strips of steel in one cab just to add some structural reinforcement but that was a special case. The only reason that I would fill the channels in on a cab floor would be so that the carpet laid flatter. I have some resin that sets up with the consistency of hard rubber...I think that I will pour that in the channels on my current project.
Old Aug 2, 2012 | 04:25 AM
turnrjr's Avatar
turnrjr
Wayne I was just wondering if the finished floor material might ripple in those areas.
Old Aug 2, 2012 | 12:47 PM
jaye's Avatar
jaye
When I put lizardskin on my floor it kinda filled in the indent you cant feel or see any ripples in he carpet. The carpet also has juking on the back.
You can see some indents after installation of the sound deadner however the capet juking covers them pretty good.
Old Aug 2, 2012 | 05:21 PM
rhopper's Avatar
rhopper
I read in street rodder that one high end rod shop uses plywood on the floor. I don't know if he glues it to the sheet metal but he uses it for the pupose you asked. Levels the floor and has alot of damping.
Old Aug 2, 2012 | 09:27 PM
52 Merc's Avatar
52 Merc
I would think that would depend entirely on what you plan to use for flooring. If you're going to cover it with a sound deadener and thick carpet with jute backing, like Jaye, you probably won't notice anything or have an issue. If you want a rubber mat on the bare floor, Ford did have a filler in the grooves for a flatter lay. It was a hard rubber substance like a seam sealer.
Old Aug 2, 2012 | 11:03 PM
teardropty's Avatar
teardropty
Personally, once I place insulation, jute backing and carpet over the ribs you never see them. Just my experience. Every cab I have seen that uses filler strips, filler, etc. just seems to be a magnet for rust.
toby tough
Apr 19, 2015 08:06 AM
my1954fordf100
Jan 29, 2015 06:10 PM
blue57
Oct 25, 2011 10:59 PM
rtcalabrojr
19
Nov 27, 2004 11:30 AM
Kenny
Sep 28, 2000 06:37 PM
