High EGTs
Old Jul 29, 2012 | 10:45 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
High EGTs
We all know high EGTs are bad. 1250* is the magic number. These are things we hear all the time.
But what I have NEVER heard, is what happens if it gets too hot? What is it that we are afraid of hurting? The turbo? The cylinders? Heads?
Old Jul 29, 2012 | 10:47 PM
BigAlsPSD's Avatar
BigAlsPSD
Cracking/melting of the pistons.
Old Jul 30, 2012 | 12:56 AM
LifeIsGood85383's Avatar
LifeIsGood85383
Good question, I thought the same too.... great answer...that would be bad....
Old Jul 30, 2012 | 01:06 AM
twags6's Avatar
twags6
Your pistons could look like the ones in Joe's post here at the nation Pyrometer Gauge - Ford Powerstroke Diesel Forum
The turbine fins on the exhaust side can also overheat and bend/melt.
Old Jul 30, 2012 | 05:52 AM
JOHN2001's Avatar
JOHN2001
We're worried about heat soak. Hitting 1600* isn't going to hurt anything as long as you don't keep it there too long. A drag strip pass or sled pull is fine. I was in a mud bog awhile back and my egts were threw the roof but that's to be expected. When I pulled out the egts at an idol were at 700* it took about 4-5 mins of letting it run parked to get back down to 300*
Old Jul 30, 2012 | 11:33 AM
CSIPSD's Avatar
CSIPSD
Your watching EGT's to protect the pistons. Period.
Your motor will blow to little aluminum pieces long before you will damage the exhaust side from EGT's.
Pistons is it.
Old Jul 30, 2012 | 04:30 PM
GonzoCSU's Avatar
GonzoCSU
I saw a diesel smoker tractor last weekend melt the exhaust fins in the turbo from a sled pull. He didn't get the head off yet so I don't know if the engine is ok, but the turbo is impressive.
Old Jul 30, 2012 | 04:36 PM
CSIPSD's Avatar
CSIPSD
Lots of water injection can keep the intake temps down enough to where that can happen, but in a normal set up its not possable.
Just search on youtube powerstroke turbo jet...
Old Jul 30, 2012 | 04:51 PM
GonzoCSU's Avatar
GonzoCSU
Now that you mention it I think he is running water injection. I am not sure what his exact setup is.
Old Jul 30, 2012 | 06:00 PM
Bonanza35's Avatar
Bonanza35
Joe, where did you get your water, meth injection from. Can you post the site. Also did they supply the 9 gallon tank. And do you just use water or both? I know some people say just the water is enough but I couldn't see how it would help in power. Thanks,
Chet
Old Jul 30, 2012 | 06:16 PM
CSIPSD's Avatar
CSIPSD
I prefer cooling mist...
Water Injection, Methanol Injection, Alcohol Injection Systems | Coolingmist
Run water injection to cool the fire... Run fuel to fuel the fire...
If you want more power, look elsewhere. While you gain some power with water/meth injection your much better off to run more fuel.
Old Jul 30, 2012 | 06:37 PM
Bonanza35's Avatar
Bonanza35
Thanks Joe, it is to just cool the fire while towing. My boy needs this in his 6.0 also. He pulls way bigger then me. Okay after looking what kit do you recommend? Its for towing heavy, and I'm going to have 200/80 sticks soon. Thanks
Chet
RV_Tech
32
Nov 26, 2016 10:29 AM
frdf250
Jun 22, 2016 07:01 AM
blk92prostreet
Nov 7, 2012 02:45 PM
Chad Shaver
May 17, 2010 12:54 PM
SpartanDieselTech
Jan 22, 2005 12:40 PM
