alignment issue
Old Jul 28, 2012 | 04:33 PM
dieselboy123's Avatar
dieselboy123
alignment issue
hi I got an 2001 f250 4x4, I have a question for you guys, what are
you guys running for your big tires? because I have aftermarket
rims running 285/75R20s and in order for it not to rub on the leafes
I had to put spacers in, 2" spacers. now I know most people are not running
spacers with big tires, I want to get rid of the spacers but don't want
it to rub, I also want to put 35"s on, what do I have to do to get rid
of the rubbing issue? I know my front end is sagging a little because I dont
think it's sitting right. do you guys have any sugestions for my issue?
Old Jul 28, 2012 | 06:09 PM
ToMang07's Avatar
ToMang07
I would lose the spacers and get appropriately sized rims with an offset. I have a leveling kit on X-code springs and my 315-75-16's clear the metal fenders/bumper, but they rub the plastic at 3/4-full lock. Nothing that bothers me tho. Best bet is a 4-6" lift.
Old Jul 28, 2012 | 06:10 PM
ToMang07's Avatar
ToMang07
Old Jul 28, 2012 | 06:15 PM
dieselboy123
are you using factory rims with those tires?
Old Jul 28, 2012 | 06:59 PM
ToMang07's Avatar
ToMang07
Nope. Stockers are 16x7, these are 16x10s. Not sure the offset tho.
Old Jul 28, 2012 | 07:33 PM
dieselboy123
anybody else have any sugestions, I would like to keep my 20"s if I can
Old Jul 29, 2012 | 01:57 AM
Ford79's Avatar
Ford79
You likely need different wheels. Factory wheels have something like 4.25" backspacing. Some aftermarket and 2005 and up wheels have right around 5"backspacing, which it sounds like you have now. Either going to need different wheels or keep the spacers.
Old Jul 29, 2012 | 08:22 AM
dieselboy123
do you think if I put a 4" lift on and took my spacers out that it wouldnt
rub on the leafes anymore? or maybe even just a 2"?
Old Jul 29, 2012 | 08:53 AM
Ford79's Avatar
Ford79
No, all that will do is give you more clearance between the tire and body.
What you have going on is a wheel backspace issue hence the need for spacers to keep the tires off the leaf springs.
Here is a write up on how to measure wheel backspace.
How To Measure Wheel Backspace - WILD HORSES Off-Road Technical Support
Old Jul 29, 2012 | 10:22 AM
jwhitetail's Avatar
jwhitetail
Weld a nut on the bump stop on the axle, it won't turn as sharp but it won't hit the leaf spring.
Old Jul 29, 2012 | 08:49 PM
Ford79's Avatar
Ford79
The only ways to fix the issue, IMO, is to get the right wheels on there or run a shorter tire.
farmall92587
Mar 29, 2015 08:17 AM
duff429
Jan 23, 2013 02:51 PM
94WhiteF250
Apr 1, 2011 01:53 PM
F-250 FX4
Feb 3, 2009 11:47 AM
