frount end
Old Jul 28, 2012 | 11:50 AM
lauxford's Avatar
lauxford
frount end
ok i got a 1995 ford f 150 4x4 got that independent frount end . when i back up in this thing my frount tiers toe in at the top probly 2 inches what is cousing this and how can i fix it . I calld a ford deler told them this and thay sead there is nother to fix it but i know thay didnt sell the truck like this off the show room floor. Pleas help any info is better then i got atm!
Old Jul 28, 2012 | 11:53 AM
Midnite1987's Avatar
Midnite1987
When you back up the front end naturally drops a bit which is what gives you the "camber" to be off on the tires. It's normal for the TTB front end on these trucks. Drive forward again and its back to normal
Old Jul 28, 2012 | 11:55 AM
Midnite1987
If your front springs Re weak it may cause it to sag a bit farther. Just a thought
Old Jul 28, 2012 | 12:06 PM
lauxford's Avatar
lauxford
i got a new 4 inch lift so new springs . only reson i was tryn to fix this is it seams to kinda bind when i back up
Old Jul 28, 2012 | 12:08 PM
White 97 xlt's Avatar
White 97 xlt
Has it ever been to an alignment shop??? Did you put in the correct camber bushings with those "lift" springs? also Too much toe in will cause it too........
Old Jul 28, 2012 | 12:10 PM
lauxford's Avatar
lauxford
hmm no but i do think i need new tierods so ill fix that and se what it will do
Old Jul 31, 2012 | 08:05 PM
minnesotafisherman's Avatar
minnesotafisherman
If you just put in a suspension lift, then you need to get the thing aligned. Front end isn't going to sit perfectly straight after messing with the suspension, any time you do it needs to be aligned.
Celicadude
Aug 31, 2006 11:10 AM
msthavchrome
Oct 21, 2004 11:12 AM
milesburns3
Jul 22, 2001 08:23 PM
milesburns3
Jul 21, 2001 01:39 PM
