2.3 No start, no spark
89 2.3l 4x4 will crank just fine but no start. It is getting plenty of fuel. Replaced ignition module,crank sensor,computer, checked all fuses. I've been looking for a broken wire with no luck. Doesn't seem to be getting any power to the coil packs. Any ideas to try out?Truck was not driven very often until a month ago. Started up fine everyday until the no start.Thanks for any help!
The Hall Effect sensor in the distributor instructs the module to fire the coil.
See if this helps you:
Ford Ranger/Bronco II TFI Ignition Diagnostics
Well the body is an '89 for a fact, but from everything I've found, I'm startin to think the motor is a '90. Bought the truck from a friend who knows nothing about the history on it. This is my first time on a 2.3 like this. Turns out my multimeter was a POS, I'm getting power to the coil packs, ignition module, and crank sensor but still no spark. Stumped.
This is starting to sound like the PCM, but some thoughts.
You said that it's getting fuel, but the pump should shut off after 2 sec until the PCM knows that the engine started (crank signal ?). If it keeps running that's possibly the PCM
- does the PCM have power? I think that it gets 12v through the EEC relay just like the injectors and the coil packs, but from a separate wire.
- If you can get to the cam and crank sensor outputs with a dvm, you MIGHT be able to see that they change.
- analog ( needle) meter would be better
-scope would be the best
Crank and Cam signals have to be in sync to cause firing. Don't know what the pattern is, and you definitely need a good scope to see it. (probably a storage scope). The PCM might not have any codes for sensors not in sync.
Good Luck,
hj
Good Luck,
hj
In spite of the fact you say it gets fuel have you tried giving it a shot of starting fluid to see if it will fire up and then stall when it's used up the starting fluid? You could have fuel but low fuel injection pressure. I know it has been mentioned already but how old is the timing belt? May have jumped a cog or two( old/stretched/missing cogs you can't see) and is now so far out of time it won't crank. Have you checked compression/plugs/wires/ ?
Fessik
04-21-2011 07:02 PM
