I just picked up a "new" (it's been hanging around, but unused) class IV Putnam hitch. For reference, it's part# CJ442-25010, or more often referenced as just 25010 I'm finding.
Putnam is no longer in business, so I can't call them for help, but I imagine most installations are similar. This hitch has a total of 6 contact points - 3 on each side (duh).
My primary question has to do with where to locate the hitch on the frame, from a front to back perspective. Should I grind off the rear-most factory rivets (the one that fastens the rear cross beam on each end), and then re-use that hole to do double duty via a bolt on each side? Or do I leave that in place and just drill three new holes on both sides?
Usually (but not always) the part that goes over the rivets has a cut-out for them..hard to describe, but I'll post a picture of it for you later today. I would NOT grind down those rivets, though. Sometimes if you're working with a 'universal fit' type hitch you have to make a few mods like drilling new holes, etc. All in all it is not a hard install provided that you are working with the correct hitch for your vehicle. Give me a few hours & I'll post those pix!
Roger
The Class IV Valley hitch I had on my last two '93 Lightnings and my recently sold 1992 F350 sounds very similar to the one you have. I ground off those rivets, drilled out the holes a bit then used it as a mount point. I always had plenty of clearance for the spare tire when placing the hitch in this location.
Thanks for the feedback - looks like a "tie" vote so far!
Some additional data... This is NOT one of those "fits-all" hitches, it is specific to the F-150 (also fits '72 - '96 Dodge trucks since they happen to have the same rail spacing).
At a minimum I'll need to drill four holes (two on each side), it's just a question of whether I drill a new one for the rear-most location or grind the rivets out and use the existing hole vacated by the rivet (as rla2005 has suggested immediately above).
As a general guide, I'm thinking that you want the hitch receiver to be about flush with the vertical plane of the bumper, yes? Or should I want it to be inboard a bit?
I bought an unknown brand of receiver hitch off of craigslist that came off a 92 F250. I cleaned it up and gave it a coat of paint. It fit around the rivets perfectly. I had to drill 3 holes on each side because this truck did not have a hitch on it previously. I used 1/2" grade 8 hardware.
