360 rebuild questions
Old Jul 26, 2012 | 11:14 PM
breedo99's Avatar
breedo99
Well looks like i am about to get my 360 rebuilt....what are the dos and donts on rebuilding the engine? should i go ahead and turn it into a 390? cam? etc....it will be mainly a hunting truck but i wouldnt mind spicing it up a bit
thanks
Old Jul 26, 2012 | 11:41 PM
HIO Silver's Avatar
HIO Silver
Dos:
Do your homework!!!
Build the engine as a system and build for reliability and longevity. The K.I.S.S. principle applies
Improve the FE oiling system by restricting the top end thereby feeding more oil to the mains.
Do use quality parts.
Limit the carb to 600-650 cfm. High revers FEs are not
Do find a good machine shop. Head to some car shows or GTGs and ask questions.
Do keep your work area organized, clean, and picked up.
Do use a torque wrench. I have never seen a calibrated elbow.
Do be patient and establish clear expectations with your machinist.
Do establish a budget with a 20% over allowance.
Do treat every part of your engine like a work of art. Need to de-rust parts? Check out my very cheap and effective set-up: https://www.ford-trucks.com/forums/1...l#post12033501
Dont's:
Don't tell your machinist about the extra 20% in your budget!
Don't be a pest around your machinist. Call before visiting.
Don't be in a hurry.
360 vs 390? Your call... I would do a mild cam.
Old Jul 27, 2012 | 12:00 AM
mikeo0o0o0's Avatar
mikeo0o0o0
If you go the 390 route, consider using the 390 flat top pistons to bump the compression ratio up. The 360 had a very anemic cr.
Old Jul 27, 2012 | 02:22 AM
bamaf150's Avatar
bamaf150
Breedo, if you want to stroke it to a 390 I've got a crank and set of rods to do that, arent you in Louisiana?
tylstruck
36
May 27, 2020 05:49 PM
74f100sc
15
Feb 23, 2016 11:26 PM
custom cabby
Sep 12, 2008 08:02 PM
tonpartain
Jan 17, 2006 07:00 AM
Country Kid
Jan 18, 2005 12:10 PM
