Help with new trailer lights
Old Jul 26, 2012 | 02:41 PM
cabloom300's Avatar
cabloom300
I put i set of led tail lights on my trailer and the only thing i have is running lights. I have power to the wire right off the lights for the turn signals and brake lights but neither of the lights will work, what might be my issue here? Thanks
Old Jul 26, 2012 | 03:28 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Did the lights come with the voltage resistor? You just can't install LED's without the adapter. Check the manufacturers web site to see if they also sell the hookup adapter. Lots of them now come with the resistor built into the LED case.
Old Jul 26, 2012 | 10:33 PM
cabloom300's Avatar
cabloom300
I assume they did since i bought it as a kit. I would think since the running lights worked that that wouldnt be the problem. I ended up hooking the ground up straight to the new cord but i saw that i needs to be grounded to the trailer, il try this and see if it works.
Old Jul 27, 2012 | 08:43 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Before you doing any wiring you should test for voltage either with a voltmeter or a test light.
Old Jul 27, 2012 | 03:54 PM
cabloom300's Avatar
cabloom300
Ive been using a test light for the tests im running but i will check for voltage as well.
Kelpy1
Mar 9, 2017 09:31 PM
arjr111
All Things Towing
16
Mar 14, 2009 10:37 AM
Brcuda
Sep 22, 2008 07:52 PM
nelly781
1978 - 1996 Big Bronco
Jun 23, 2004 04:53 PM
heffro
1983 - 2012 Ranger & B-Series
Feb 28, 2004 12:36 AM
