speedometer setup?
Old Jul 25, 2012 | 08:21 AM
darkpurp1e's Avatar
darkpurp1e
speedometer setup?
HEY everyone, ok so heres what in dealing with: my 78 bronco on a 94 f350 frame, with the 7.3 diesel in it, and a 5 speed standard behind it. im trying to hook up gauges now and trying to figur out the best way to hook u the speedo. i would like to use the factory cable driven one thats in the bronco, but i understand that might not be practical. let me know what you think, im going to post in the bronco forum as well. thanks again
steve
Old Jul 25, 2012 | 08:40 AM
bashby's Avatar
bashby
Does your transfer case have the spot for a speedo gear? If not you can get one that does.
Old Jul 25, 2012 | 09:58 AM
farmert's Avatar
farmert
To use the speedo from the 78 bronco, you will need to use a pre 92 transfer case, as in the 92 and later speedos read from the rear axle. Your Bronco should have the 203 or 205 transfer case, which will bolt to the Zf5, but you will have to mod the linkage or the webbing on the case (cant remember which) to make it work. My 85 has a 208 case behind the zf I put in iit, I had to shorten the linkage to get the shifter to line up. A 1354, or a pre 92 1356 case should also work.
Old Jul 26, 2012 | 08:08 AM
darkpurp1e's Avatar
darkpurp1e
the entire drivetrain is from the 94 f350, so im pretty sure its the Borge Warner 1356 transfer case. i do not have any of the bronco's drivetrain.
Old Jul 26, 2012 | 08:10 AM
darkpurp1e's Avatar
darkpurp1e
which is a 94 so it sounds like im out of luck huh
Old Jul 26, 2012 | 10:20 AM
bashby's Avatar
bashby
Buy a 1356 with the zpeedo provision from eBay or Craigslist then sell yours
chicagodragon
1978 - 1996 Big Bronco
Sep 6, 2009 09:28 PM
gonecrazyi
Sep 23, 2007 09:33 PM
scottddove
Aug 22, 2006 11:23 PM
OLD_84_Bronco
Mar 1, 2004 03:47 PM
