5L EFI stumbles while accelerating (sometimes)
Old Aug 9, 2012 | 07:02 AM
  #46
c2z4s9's Avatar
c2z4s9
Right, I got 11 (PASS) for KOEO test. So that means I should try the engine running test.
Old Aug 16, 2012 | 08:11 PM
  #47
c2z4s9's Avatar
c2z4s9
OK, I have been gone for a while -- just running the truck. I have driven the truck several hundred miles since clearing the codes. Since then I have not experienced this stumbling upon acceleration, and I re-checked the codes today and there were no error codes, just the pass codes. It's a little frustrating nothing has resurfaced, because I didn't really "fix" anything other than replacing the fuel filter.
If something comes up I'll post it here. It would be nice to have a clear resolution, but I suppose I should be happy I'm not having any problems.
Thanks everyone for your help.
Old Mar 12, 2013 | 03:20 PM
  #48
c2z4s9's Avatar
c2z4s9
For the sake of completeness I wanted to finish this thread. I replaced the fuel filter (as described) and didn't encounter any more truck dying issues; I suspect the fuel filter was simply clogged with garbage pulled out of the broken (and rotten) rear pump. Fine.
Vacuum was not as was to be expected and I heard a sucking sound when pressing on the brakes. Replacing the brake booster fixed the vacuum problem and improved performance a bit.
Lastly, the truck would always start strong when cold, but if shut of and restarted when warm it would not always run as great; it would run rich and crappy. Also, I was getting a computer "Code 18 is telling you the computer isn't getting the correct signal from the distributor pickup (aka stator, a hall-effect device)". I replaced the distributor (module) and this resolved the final issue.
Now the truck runs strong, always.
Next, I should lift it.
Old Mar 12, 2013 | 07:17 PM
  #49
RAY1986F150's Avatar
RAY1986F150
Glad you got it running good. Ive had mine running good for a year or so now and it is very reliable, starts well in the cold or hot.
Old Nov 9, 2016 | 04:50 PM
  #50
vjsimone's Avatar
vjsimone
Following....
Old Nov 9, 2016 | 06:17 PM
  #51
FuzzFace2's Avatar
FuzzFace2
Originally Posted by vjsimone
Following....
VJ what are you following?
Last up date was 2013!
Dave ----
Old Nov 9, 2016 | 07:15 PM
  #52
vjsimone's Avatar
vjsimone
Dave ----
Following the wrong path,,, missed the date this time...
Jimmy Crab
55
Aug 28, 2016 04:56 AM
Doubter123
Jun 21, 2013 08:13 PM
ewellman
Aug 29, 2012 07:27 AM
FourXFord2
1978 - 1996 Big Bronco
20
Jul 23, 2012 07:39 PM
Sweetred95ta
Jul 26, 2005 09:23 AM
