Sponsored by: Auxito
Need help with lights plz! =(
Old Jul 23, 2012 | 06:47 PM
jackrabbit72380's Avatar
jackrabbit72380
have checked all wires for krosion and fuse's are good so confused!
Just put brand new tail lights bulbs in!
The top one comes on as a running light but nothing else works
I also checked under hood fuses too!
=( dont know what to do now Im so stumped?
1.Only Hazerd light that works is on the Right Front passanger side.
2 Drivers side Break Light & Turn Signal Dose'nt Work. BUT PASSANGER WORKS FINE!
LEFT TURN SIGNAL IS OUT AND BLINKS REALY FAST! =(
3.Passanger Side Overhead Outside Light on cab is out . okay thats probly just a bulb!
Dont know what to do now?
Old Jul 23, 2012 | 07:46 PM
dbreckman's Avatar
dbreckman
Jackrabbit check the post about trailer light trouble from earlier today. They talk about a couple of hidden fuse boxes in the engine compartment. Not what year you're working with but I don't see either box on my 01 scab, but I didn't look real hard as I'm not having any issues.
Old Jul 23, 2012 | 07:54 PM
jackrabbit72380
O sory...:\
I have a 1997 f-150 5.4 L
Yeah I read that this morning. Glad I found that thread to because i could not figure out what that box was. but now I know its for the tow kit my truck has on the back incase I hook up a boat or something. I knew it would not make any diffrence but just for giggles I cleaned inside the conecter for the boat hook up and checked all the resisters in that box
weard that that bo is not in the owners manul but none the less i alredy trouble shot that and its not the problum or so it seams anyway i still wish i had a diagram on that box id like to know what amps the relays are. but I dont think it will solve my problum. =( very unfortunate
any other idias?
Old Jul 23, 2012 | 08:10 PM
dbreckman's Avatar
dbreckman
Sounds like the main trouble is in the blinker circuit. Did you check the turn signal relay in the inside fuse panel. Not sure which one to tell you it is since their not round anymore and I don't have my owners manual handy. The outside lamp over the cab is probably just a bulb, since its on the opposite side from the rest of the issues. Other than that possibly the wrong bulbs (make sure you have double filament for the brake/signal. Swap the bulbs from the passenger side to the driver side and see if the problem remains.
Old Jul 23, 2012 | 08:18 PM
jackrabbit72380
Turn signal relay in the inside fuse panel would be for both turn signals left and right am I right?
Would'nt that pritty much rule out the relay being bad? Sence the other side works fine?
Would'nt that also rule out the turn signal switch?
I do have the user owners manual handy and most of the info strarts on page 140.
I have been stareing at three pages for 3 days go figure!
double checked all the fuses!
as for relays I dont realy see how I could test them? besides its not like i can switch them around when thare diffrent amps.
the only store around is advanced discount auto parts and pritty much everyone i have asked for help has been mind bogled we just cant figure out whats wrong very odd indeed
even odder i asked a guy for help that works in wallmart automotive and he says to me hay gess what i have a 97 ford expedition and im haveing the same problum im like OMG!
Im not sure what Double filament meens but the bulbs I bought are same as last time i had a bulb go out on me about 4 years ago.
thay are SYLVANIA LONG LIVE 3157 LL.
PS:You can download the owners manual hear if you like...
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Jul 23, 2012 | 08:25 PM
dbreckman's Avatar
dbreckman
Yes that relay would be for both signals, however its a four prong relay. two for the left and two for the right. depending on the MFS position or hazard switch the circuit would either be open or closed. downloading manual now.
Old Jul 23, 2012 | 09:05 PM
jackrabbit72380
thanks for trying to help realy haveing a hard time hear are you saying 1/2 of the relay might be bad?
Old Jul 23, 2012 | 09:19 PM
dbreckman's Avatar
dbreckman
Yes. try swapping the bulbs from the passenger side with the driver side just to rule out the bulbs
Old Jul 23, 2012 | 09:20 PM
jackrabbit72380
Well thare brand new I had them tested at advanced autoparts right after I bought them. AND the top one works as running light but the fact that no hazerd lights work exept for the yellow one on the front passenger side makes me think my problum lies else ware?
Old Jul 24, 2012 | 03:03 PM
jackrabbit72380
Well I checked the one from the other side anyway and still no go but my hazerd lights work now exept the drivers side back that im haveing problum with i havent seen any relay related stricly to the left blinker and break lights on the left so im still stuck and very much need some help if anyone else has any sugjestions?
Old Jul 24, 2012 | 03:13 PM
dbreckman's Avatar
dbreckman
Check the contact points in the socket, you may have to pull them in a bit to make sure you're getting a good connection on the bulb contacts. I know its a whole different animal but I use to own a Chevy that had the same issue and that was the problem
Old Jul 25, 2012 | 09:43 AM
jackrabbit72380
The bulb lights up when the running lights are on just no turn signal or break light. same bulb its hiting the contacts for sure.
Old Jul 27, 2012 | 01:42 PM
jackrabbit72380
can anyone help?
Old Jul 27, 2012 | 07:50 PM
jackrabbit72380
well spent another 3hr's trying to find the source today with no luck
I JUST CANT FIND it i have tryed so hard
i wish it was as simple as just replaceing the to ight sockets in the back but because of the tow kit i cant just disconect the to sockets
my hazerd lights still seem to be having problums to
im so exausted from trying to figure out why i have not break light or blinker on the drivers side
Drakester183
2009 - 2014 F150
May 11, 2018 11:10 AM
1978fordf250
Sep 18, 2010 12:36 PM
crazyjed
15
Mar 10, 2008 07:40 PM
77-400-4x4
Electrical Systems/Wiring
Mar 5, 2007 11:27 AM
tx64f100tx
Feb 22, 2006 07:32 AM
