Kept throwing cps code
Old Jul 21, 2012 | 11:47 AM
427 fordman's Avatar
427 fordman
Well, like the title said, I kept setting the cps code, 0344, even after changing to my new sensor. Also last time I drove it to the track, it bucked real hard once, throwing no other codes. So, this morning I pulled the wiring leading to it. A few chafing marks on the brown wire, I'll put a pic up, kind of hard to see in it, but they are there.
I cut all three of them right behind the plug and at the main harness. Then I soldered in new larger gauge wires and put new heat shrink, elec. tape, and loom to cover them. Didn't drive it except out of the ac part of the shed to one of the cold (or hot as the case may be) storage sides. Hopefully that takes care of my code.
I guess all I'm saying is make sure you check your wiring to the cps if you are having issues. I know its been mentioned before, just passing along my experience.
Old Jul 22, 2012 | 10:09 PM
fordpride's Avatar
fordpride
I like a easy fix. Thanks for the info
Whitey Ford
17
Jan 5, 2024 10:47 PM
KH85
Jan 3, 2014 10:53 PM
blrman1962
Mar 8, 2013 04:12 PM
10bands
Apr 30, 2007 07:37 PM
gotama
Sep 27, 2006 07:26 PM
