The AOD can be used heavy truck work, just do like the Owner's Manual says and keep it out of OD when doing that.
It can be used for towing, and even heavy towing - assuming a decent axle ratio and proper technique. The axle ratio makes a big difference, and many of the 392/AOD combos had cruising gears and not towing gears. So, that needs to be checked if the OP is going to tow.
Having said, Ford didn't put the AOD behind any of the other V8's for a reason.
Thank you do much I need buy new transmission cause mine is slipping really bad
If you have to replace the tranny then you have a choice of the AOD or C6. The AOD is the better for economy and the C6 is better for towing. As Chris says, you have to figure out the primary vs secondary use.
