460 efi
Old Jul 20, 2012 | 12:49 AM
tintop48's Avatar
tintop48
460 efi
im trying to better understand the workings of my truck,1994 f-250 460.i believe that it is a speed density system meaning an unsophisticated injection system? what type of ecm is used?if i wanted to do some upgrades for a torque increase could it be reprogrammed? thanks
Old Jul 21, 2012 | 09:33 PM
Lead Head's Avatar
Lead Head
Speed-density is not necessarily unsophisticated. It just means the computer makes some assumptions based on measured engine volumetric-efficiency and manifold vacuum.
Old Jul 21, 2012 | 11:59 PM
tintop48's Avatar
tintop48
460 efi
Lead Head, can i make changes to cam and heads while still being speed density? thanks
Old Jul 22, 2012 | 12:22 AM
Lead Head's Avatar
Lead Head
You can make mild changes. You would want to use a cam that does not have a lot of overlap. To get the most out of it, you would have to find a shop capable of tuning the computer for you.
If you had Mass-Air, it would be more forgiving towards modifications.
You may get more help in the 87-96 F-Series forum, than in here though. It's far more active then this small subsection.
Old Jul 22, 2012 | 08:44 PM
BrianDguy's Avatar
BrianDguy
What, and more importantly, why are you trying to understand whats going on under the hood?
There is nothing wrong with SD, as long as you know its limits. For the vast majority of people, stock speed density is more then capable of dealing with power increasing mods.
There are to many things going on to be able to give you a quick run down.
TOMBA1959
Feb 6, 2011 01:06 PM
4x41977
Jan 13, 2011 03:40 PM
kellar
Jan 29, 2008 03:09 PM
BroncoChet
Jan 1, 2006 02:29 PM
PHOTOG101
Apr 4, 2005 06:30 PM
