FUEL FROM THE SD EFI SYSTEM
Old Feb 5, 2011 | 04:33 PM
TOMBA1959's Avatar
TOMBA1959
I know this seems to be an endless debate over the efi's in the 90's. I have picked up a 96 460 efi with the speed density efi system on the engine. It will be installed in my 59 F250. I know the engine only puts out apx 250 HP,and I want the HP to be 450 avg. I also have learned that the SD system is designed for the HP it makes from the factory. I Imagine Ford has an RV type cam that can be put in. I dont think that is going to get me where i want. Can the SD system / EEC IV be re tuned with a larger cam without killing the vaccum that the SD cam needs to function? Or do I have to go MAF? Trying to stay on a budget, but what would be the best apporach? I do have all the goodies needed to run the EFI(computer, harness, etc.)
Appreciate your input................
Tom
Old Feb 5, 2011 | 05:21 PM
sdetweil's Avatar
sdetweil
I don't think you can use SD and get the changes you want. on all the stangs of this vintage you need MAF to deal with the airflow changes.
sam
Old Feb 5, 2011 | 05:23 PM
2dasand's Avatar
2dasand
The speed density system is a little tricky, as you stated. I am pretty sure that it can be chipped to attain what you want, but the SD will always be a limiting factor. I would think putting a 5.0 computer on it would be the best way to go. I would call Steve @ Powertrain Dynamics in Huntington Beach, Ca. He is one of the best EEC-IV tunes around, IMHO. He is a one man shop, so leave a message, and he will call you back (usually the next morning).
Old Feb 5, 2011 | 05:38 PM
havi's Avatar
havi
I'll have the Roast Duck
I agree with the others here, I would say a MAF system and aftermarket ECM.
Old Feb 5, 2011 | 06:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If you want 450 HP you would be better off going with a carb IMO.
Old Feb 5, 2011 | 07:05 PM
TOMBA1959's Avatar
TOMBA1959
sd to maf or?
Ok guys,I think I am convinced that the SD would hinder my plans. I do want the benifits of FI,so I will start with contacting powertrain dynamics and go from there.Thanks for the support !!
Old Feb 5, 2011 | 07:25 PM
sdetweil's Avatar
sdetweil
My 460 is at 436hp, 489ft/lb torque. Carbed
With the 69 (c9ve) hi compression heads. I could have had another 50hp if I had picked the right cam.
Don't know how u can do this with the lower compression efi heads.
Sam
Old Feb 6, 2011 | 01:06 PM
TOMBA1959's Avatar
TOMBA1959
EFI OR CARB
Sam, good point. I just haven't looked into what another set of heads would cost. I am going to completely tear down the engine to refresh it, original (65,000 miles) so maybe I should keep this in mind. Does anybody else have any ideas on what heads to look for if I go carb? Or are the c9ve's the way to go? Will have to change pistons because of the low compression they make or will the combustion chamber size adjust it?
Tom
